[SOLVED] Old power supply with 4-pin CPU connector powers just fine, new one with 8-pin CPU connector gives red CPU light and no POST.
Dec 28, 2022
The old power supply was pulled from an old office PC, the new one is a thermaltake toughpower gf1 650w. Whenever I power on the PC with the new PSU (8-pin ATX CPU connector) it won't POST and gives me a red light on the motherboard indicating a problem with the CPU. The old PSU (4-pin ATX CPU connector) works just fine but won't have enough wattage for the upgrade I'm trying to do.
Specs:
Intel core i7-9700k
Gigabyte Z390 UD
Thermaltake Toughpower gf1 650w
Nothing else is plugged in right now, but if you need the other specs I can share.
Make sure that both the 8-pin and 24-pin PSU cables are firmly attached at both ends (motherboard and PSU).
Also, make sure you don't re-use any power cables from your old PSU with your new PSU. Cables are not interchangeable between makes/models.
