Question older asus build - having cooling issues
adamghering
33
Ive had this build for quite some time and Im not able to upgrade (working with what I have)
Ive gotten into hardware monitoring and trying to make my rig as efficient as it can be.
Ive used several hardware monitors , NZXT, HWinfo, Speedfan etc
and the temps are weird, my CPUs are running within parameters idle and at load but across all monitor programs my SystIN is over 100 deg celcius.
I was able to adjust the fans in the bios finally but there seems to be limited control.
auto seems to run things as idle as possible and no matter what the temps they dont seem to speed up
usually around 300-500 rpm
I put them at high setting and that yielded 500-800 rpm
then I put them at full speed
the reading says they are running at 1200-1500 rpm depending on the fan buuuuut.
the hwinfo readings are still the same as if the fans arent going any faster....Im at a loss here
posting the txt file
asus Z10pe-d16 ws
64 gb ram 2400
dual gtx 1080s
dual xeon E5-2640 v4 processor
CPU coolers x2 noctua 14s (i believe)
case Phantek enthoo pro
x2 noctua bottom case fans
x2 noctua ceiling case fans
x1 giant front panel phantek case fan
x1 phantek rear case fan 15
all front and bottom case fans are blowing into the case
all top and rear case fans are blowing out of the case
but I cant get the fans to throttle up at all.
but if anyone has thoughts?
Ive also noticed a new development of one of my ssds is not noticed by bios on boot occassionally and the audio through my focusrite is becoming garbled and having digital crunchy dropouts sometimes.
hwinfo txt file
CPUID HWMonitor Report
Binaries
HWMonitor version 1.4.8.0
Monitoring
Mainboard Model Z10PE-D16 WS (0x000002F2 - 0x881AB860)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6779
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC5
LPCIO Revision ID 0x62
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF 00 00 FF FF FF FF FF 00 70 E6 00 FF FF
20 C5 62 FF 00 00 00 10 00 00 FF 00 00 00 FF 00 01
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 00 30 FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Nuvoton NCT6779
Voltage 1 0.22 Volts [0x1B] (VIN1)
Voltage 2 3.31 Volts [0xCF] (AVCC)
Voltage 3 3.30 Volts [0xCE] (3VCC)
Voltage 4 0.36 Volts [0x2D] (VIN4)
Voltage 6 0.83 Volts [0x68] (VIN6)
Voltage 7 0.71 Volts [0x59] (VIN7)
Voltage 9 0.21 Volts [0x1A] (VIN9)
Voltage 10 0.36 Volts [0x2D] (VIN10)
Voltage 11 0.22 Volts [0x1B] (VIN11)
Voltage 12 0.83 Volts [0x68] (VIN12)
Voltage 13 0.21 Volts [0x1A] (VIN13)
Voltage 14 0.22 Volts [0x1C] (VIN14)
Voltage 15 1.65 Volts [0xCE] (VIN15)
Voltage 16 0.21 Volts [0x1A] (VIN16)
Temperature 0 100 degC (212 degF) [0x64] (SYSTIN)
Temperature 1 90 degC (194 degF) [0xB4] (CPUTIN)
Temperature 3 40 degC (104 degF) [0x28] (TMPIN3)
Temperature 5 89 degC (192 degF) [0x59] (TMPIN5)
Temperature 6 100 degC (212 degF) [0x64] (TMPIN6)
Temperature 8 91 degC (195 degF) [0x5B] (TMPIN8)
Hardware registers
bank 0
00 03 FF 03 FF 01 FF FF FF FF FF FF FF FF FF FF FF
10 03 FF 03 FF 03 FF FF FF 40 79 59 1C 1A 1A 1A 00
20 FF 1B CF CE 2D FF 68 64 FF FF FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
40 03 00 40 FF DF 00 1F FF 2D FF FF 10 08 55 00 A3
50 01 FF FF FF FF FF FF FF C1 FF FF FF FF 01 00 FF
60 AA FF FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
70 00 0A 00 64 00 5A 00 23 80 23 80 23 80 FF FF FF
80 FF 7F 1F BF FF 05 05 05 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4
A0 0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 00 00
B0 00 00 00 00 00 00 3A 00 04 00 00 34 28 C0 04 FF
C0 FF FF FF FF FF FF FF FF FF 09 02 02 FF FF FF FF
D0 05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD
E0 55 80 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
F0 00 00 00 00 00 00 00 00 00 00 00 0F DB FF FF FF
bank 4
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
20 FF FF FF 96 64 96 64 E1 96 04 FF FF FF FF FF FF
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF 03 14 FF FF FF FF FF FF 00 00 00 00 04 FF
50 00 73 FF FF 00 00 00 FF FF 3F 13 33 09 FF FF FF
60 FF 01 00 00 00 00 00 00 FF FF FF FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 FF 1B CF CE 2D FF 68 D6 D2 79 59 1D 1A 1A 1A 00
90 64 5A 23 2A 5B 5B 00 3A C0 64 5A 23 23 23 1C FF
A0 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00
B0 FF 1F FF 1F FF 1F FF 1F FF 1F FF FF FF FF FF FF
C0 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF
D0 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor DIMM
Temperature 0 43 degC (108 degF) [0xC2A8] (core)
Temperature 0 50 degC (121 degF) [0xC318] (core)
Hardware monitor NVIDIA NVML
Power 0 40.66 W (GPU)
Temperature 0 68 degC (154 degF) [0x44] (GPU)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.68 Volts [0x2A3] (GPU)
Power 0 40.77 W (GPU)
Power 2 8.83 W (Core Power Supply)
Power 6 28.12 W (PCIe +12V)
Power 7 11.95 W (8-PIN #0)
Temperature 2 79 degC (174 degF) [0x4F] (Hot Spot)
Fan 0 665 RPM [0x299] (GPU #0)
Fan PWM 0 22 pc [0x16] (FANPWMIN0)
Clock Speed 0 1202.00 MHz [0x4B2] (Graphics)
Clock Speed 1 5005.80 MHz [0x138D] (Memory)
Clock Speed 2 n.a. (Processor)
Hardware monitor D3D
Voltage 0 0.63 Volts [0x271] (GPU)
Power 0 8.40 W (GPU)
Power 2 2.25 W (Core Power Supply)
Power 6 4.28 W (PCIe +12V)
Power 7 3.42 W (8-PIN #0)
Temperature 0 43 degC (108 degF) [0x2A] (GPU)
Temperature 2 54 degC (128 degF) [0x35] (Hot Spot)
Fan 0 0 RPM [0x0] (GPU #0)
Fan PWM 0 0 pc [0x0] (FANPWMIN0)
Clock Speed 0 139.00 MHz [0x8B] (Graphics)
Clock Speed 1 405.00 MHz [0x195] (Memory)
Processors
CPU Groups 1
CPU Group 0 40 threads, mask=0xFFFFF00000
Number of sockets 2
Number of threads 40
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Thread 1 1
-- Core 1 (ID 1)
-- Thread 2 2
-- Thread 3 3
-- Core 2 (ID 2)
-- Thread 4 4
-- Thread 5 5
-- Core 3 (ID 3)
-- Thread 6 6
-- Thread 7 7
-- Core 4 (ID 4)
-- Thread 8 8
-- Thread 9 9
-- Core 5 (ID 8)
-- Thread 10 16
-- Thread 11 17
-- Core 6 (ID 9)
-- Thread 12 18
-- Thread 13 19
-- Core 7 (ID 10)
-- Thread 14 20
-- Thread 15 21
-- Core 8 (ID 11)
-- Thread 16 22
-- Thread 17 23
-- Core 9 (ID 12)
-- Thread 18 24
-- Thread 19 25
Socket 1
-- Core 10 (ID 0)
-- Thread 20 32
-- Thread 21 33
-- Core 11 (ID 1)
-- Thread 22 34
-- Thread 23 35
-- Core 12 (ID 2)
-- Thread 24 36
-- Thread 25 37
-- Core 13 (ID 3)
-- Thread 26 38
-- Thread 27 39
-- Core 14 (ID 4)
-- Thread 28 40
-- Thread 29 41
-- Core 15 (ID 8)
-- Thread 30 48
-- Thread 31 49
-- Core 16 (ID 9)
-- Thread 32 50
-- Thread 33 51
-- Core 17 (ID 10)
-- Thread 34 52
-- Thread 35 53
-- Core 18 (ID 11)
-- Thread 36 54
-- Thread 37 55
-- Core 19 (ID 12)
-- Thread 38 56
-- Thread 39 57
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 10 (max 10)
Number of threads 20 (max 20)
Manufacturer GenuineIntel
Name Intel Xeon v4
Codename Broadwell-E/EP
Specification Intel(R) Xeon(R) CPU E5-2640 v4 @ 2.40GHz
Package (platform ID) Socket 2011 LGA (0x0)
CPUID 6.F.1
Extended CPUID 6.4F
Core Stepping M0
Technology 14 nm
TDP Limit 90.0 Watts
Tjmax 92.0 °C
Core Speed 1197.1 MHz
Multiplier x Bus Speed 12.0 x 99.8 MHz
Base frequency (cores) 99.8 MHz
Base frequency (mem.) 99.8 MHz
Stock frequency 2400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3, TSX
Microcode Revision 0xB000036
L1 Data cache 10 x 32 KB (8-way, 64-byte line)
L1 Instruction cache 10 x 32 KB (8-way, 64-byte line)
L2 cache 10 x 256 KB (8-way, 64-byte line)
L3 cache 25 MB (20-way, 64-byte line)
Max CPUID level 00000014h
Max CPUID ext. level 80000008h
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 24x
Max turbo ratio 34x
Max efficiency ratio 12x
Max Power 180 Watts
Min Power 40 Watts
O/C bins none
Ratio 1 core 34x
Ratio 2 cores 34x
Ratio 3 cores 32x
Ratio 4 cores 31x
Ratio 5 cores 30x
Ratio 6 cores 29x
Ratio 7 cores 28x
Ratio 8 cores 27x
Ratio 9 cores 26x
Ratio 10 cores 26x
Ratio 11 cores 26x
Ratio 12 cores 26x
Ratio 13 cores 26x
Ratio 14 cores 26x
Ratio 15 cores 26x
Ratio 16 cores 26x
Ratio 17 cores 26x
Ratio 18 cores 26x
Ratio 19 cores 26x
Ratio 20 cores 26x
Ratio 21 cores 26x
Ratio 22 cores 26x
Ratio 23 cores 26x
Ratio 24 cores 26x
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
TDP Level 90.0 W @ 24x
TDP Level 90.0 W @ 20x
Temperature 0 37 degC (98 degF) (Package)
Temperature 1 30 degC (86 degF) (Cores (Max))
Temperature 2 28 degC (82 degF) (Core #0)
Temperature 3 29 degC (84 degF) (Core #1)
Temperature 4 29 degC (84 degF) (Core #2)
Temperature 5 29 degC (84 degF) (Core #3)
Temperature 6 30 degC (86 degF) (Core #4)
Temperature 7 29 degC (84 degF) (Core #5)
Temperature 8 28 degC (82 degF) (Core #6)
Temperature 9 29 degC (84 degF) (Core #7)
Temperature 10 28 degC (82 degF) (Core #8)
Temperature 11 27 degC (80 degF) (Core #9)
Voltage 0 +0.00 Volts (IA Offset)
Voltage 1 +0.00 Volts (GT Offset)
Voltage 2 +0.00 Volts (LLC/Ring Offset)
Voltage 3 +0.00 Volts (System Agent Offset)
Voltage 4 1.10 Volts (VID (Max))
Voltage 5 0.76 Volts (VID #0)
Voltage 6 0.94 Volts (VID #1)
Voltage 7 0.95 Volts (VID #2)
Voltage 8 1.03 Volts (VID #3)
Voltage 9 1.06 Volts (VID #4)
Voltage 10 0.75 Volts (VID #5)
Voltage 11 1.10 Volts (VID #6)
Voltage 12 0.94 Volts (VID #7)
Voltage 13 1.10 Volts (VID #8)
Voltage 14 1.04 Volts (VID #9)
Power 00 12.23 W (Package)
Power 01 n.a. (IA Cores)
Power 02 n.a. (Uncore)
Power 03 0.91 W (DRAM)
Clock Speed 0 1197.14 MHz (Core #0)
Clock Speed 1 3391.91 MHz (Core #1)
Clock Speed 2 3391.91 MHz (Core #2)
Clock Speed 3 2992.86 MHz (Core #3)
Clock Speed 4 3192.38 MHz (Core #4)
Clock Speed 5 3391.91 MHz (Core #5)
Clock Speed 6 3391.91 MHz (Core #6)
Clock Speed 7 3391.91 MHz (Core #7)
Clock Speed 8 3391.91 MHz (Core #8)
Clock Speed 9 3092.62 MHz (Core #9)
Core 0 max ratio 34.00 (effective 34.00)
Core 1 max ratio 34.00 (effective 34.00)
Core 2 max ratio 34.00 (effective 34.00)
Core 3 max ratio 34.00 (effective 34.00)
Core 4 max ratio 34.00 (effective 34.00)
Core 5 max ratio 34.00 (effective 34.00)
Core 6 max ratio 34.00 (effective 34.00)
Core 7 max ratio 34.00 (effective 34.00)
Core 8 max ratio 34.00 (effective 34.00)
Core 9 max ratio 34.00 (effective 34.00)
Socket 2 ID = 1
Name Intel Xeon v4
CPUID 6.F.1
Extended CPUID 6.4F
Core Stepping M0
Technology 14 nm
Tjmax 92.0 °C
Core Speed 3391.9 MHz
Multiplier x Bus Speed 34.0 x 99.8 MHz
FID/VID Control yes
Max turbo ratio 34x
Max Power 180 Watts
Min Power 40 Watts
O/C bins none
Ratio 1 core 34x
Ratio 2 cores 34x
Ratio 3 cores 32x
Ratio 4 cores 31x
Ratio 5 cores 30x
Ratio 6 cores 29x
Ratio 7 cores 28x
Ratio 8 cores 27x
Ratio 9 cores 26x
Ratio 10 cores 26x
Ratio 11 cores 26x
Ratio 12 cores 26x
Ratio 13 cores 26x
Ratio 14 cores 26x
Ratio 15 cores 26x
Ratio 16 cores 26x
Ratio 17 cores 26x
Ratio 18 cores 26x
Ratio 19 cores 26x
Ratio 20 cores 26x
Ratio 21 cores 26x
Ratio 22 cores 26x
Ratio 23 cores 26x
Ratio 24 cores 26x
Temperature 0 38 degC (100 degF) (Package)
Temperature 1 32 degC (89 degF) (Cores (Max))
Temperature 2 31 degC (87 degF) (Core #10)
Temperature 3 31 degC (87 degF) (Core #11)
Temperature 4 31 degC (87 degF) (Core #12)
Temperature 5 31 degC (87 degF) (Core #13)
Temperature 6 31 degC (87 degF) (Core #14)
Temperature 7 32 degC (89 degF) (Core #15)
Temperature 8 30 degC (86 degF) (Core #16)
Temperature 9 31 degC (87 degF) (Core #17)
Temperature 10 31 degC (87 degF) (Core #18)
Temperature 11 31 degC (87 degF) (Core #19)
Voltage 4 1.12 Volts (VID (Max))
Voltage 5 0.76 Volts (VID #10)
Voltage 6 1.12 Volts (VID #11)
Voltage 7 0.75 Volts (VID #12)
Voltage 8 1.11 Volts (VID #13)
Voltage 9 1.12 Volts (VID #14)
Voltage 10 0.76 Volts (VID #15)
Voltage 11 1.10 Volts (VID #16)
Voltage 12 1.12 Volts (VID #17)
Voltage 13 0.75 Volts (VID #18)
Voltage 14 1.10 Volts (VID #19)
Power 00 14.42 W (Package)
Power 03 0.01 W (DRAM)
Clock Speed 0 3391.91 MHz (Core #10)
Clock Speed 1 3391.91 MHz (Core #11)
Clock Speed 2 1197.14 MHz (Core #12)
Clock Speed 3 3391.91 MHz (Core #13)
Clock Speed 4 1197.14 MHz (Core #14)
Clock Speed 5 1197.14 MHz (Core #15)
Clock Speed 6 2793.33 MHz (Core #16)
Clock Speed 7 3391.91 MHz (Core #17)
Clock Speed 8 1197.14 MHz (Core #18)
Clock Speed 9 3391.91 MHz (Core #19)
Storage
Drive 0/0/-1
Device Path \\?\scsi#disk&ven_samsung&prod_ssd_850_evo_1tb#4&21407722&0&030000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Name Samsung SSD 850 EVO 1TB
Revision EMT02B6Q
Serial S2RENX0H620124P
Capacity 931.5 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Controller Serial ATA Controller - AHCI at bus 0, device 17, function 4
Volume d:\, 931.4 GBytes (23.0 percent available)
Drive 1/1/-1
Device Path \\?\scsi#disk&ven_nvme&prod_samsung_ssd_950#5&3437bb95&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Name Samsung SSD 950 PRO 256GB
Revision 1B0QBXX7
Serial S2GLNX0H707917F
Capacity 238.5 GB
Type Fixed, SSD
Bus Type NVMe (17)
Features
Controller NVM Express (NVMe) Controller at bus 7, device 0, function 0
Link Speed PCI-E 2x @ 5.0 GT/s
Volume c:\, 237.5 GBytes (18.8 percent available)
Drive 2/2/-1
Device Path \\?\scsi#disk&ven_wd_blue&prod_sa510_2.5_1tb#4&21407722&0&010000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Name WD Blue SA510 2.5 1TB
Revision 52008100
Serial 223407A016FC
Capacity 931.5 GB
Type Fixed, SSD
Bus Type SATA (11)
Volume e:\, 931.5 GBytes (10.0 percent available)
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVML
API NVIDIA I/O
API NVIDIA NVAPI
pwrMask 0x00000CDB
pwrTable [F5 F6 00 FF FA 00 F1 F1 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
Display Adapters
Display adapter 0
ID 0x1090304
Name NVIDIA GeForce GTX 1080
Board Manufacturer EVGA Corp.
Revision A1
Codename GP104-400
Core family 0x134 (GP104-A)
Power Limit 180.0 W (current), 180.0 W (default), 217.0 W (max)
Thermal Limit 96.0 °C (slowdown), 99.0 °C (shutdown)
Cores 2560
ROP Units 64
TM Units 160
Technology 16 nm
Memory type GDDR5X (Micron)
Memory size 8 GB
Memory bus width 256 bits
PCI device bus 2 (0x2), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x3842)
Model ID 0x1B80 (0x6183)
Revision ID 0xA1
Root device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Performance Level Base
Core clock 1708.5 MHz
Memory clock 5005.0 MHz
Performance Level Boost
Core clock 1847.5 MHz
Performance Level Current
Core clock 1202.0 MHz
Memory clock 5005.8 MHz
Driver version 31.0.15.3118
WDDM Model 2.7
Display adapter 1
ID 0x1090304
Revision A1
Codename GP104-400
Core family 0x134 (GP104)
Power Limit 180.0 W (default)
Technology 16 nm
Memory size 8 GB
PCI device bus 3 (0x3), device 0 (0x0), function 0 (0x0)
Revision ID 0xA1
Core clock 139.0 MHz
Memory clock 405.0 MHz
