Ive built My PC with the following components:
CPU: Ryzen 2700 3200MHz with wraith cooler
MB: Rog Strix B450F gaming motherboard
GPU: EVGA GeForce GTX 980TiSC+
RAM: G.Skill Ripjaws Vseries 16 (2x 8gb) 2400C15D-16GVR
Storage: Samsung 860 EVO 1TB SSD
PSU: EVGA 750 GQ 80+ gold
Case: Fractal Focus G
When I turn on the system I get a cycle of orange then red light blinks back and forth twice then a white light that stays lit. In the Motherboard manual the red onboard LED indicates the processor, the orange indicates DRAM and white indicates VGA. All fans and lights turn on when the system is turned on, even the LED on the GPU but I get no display signal on the monitor. So, I can't get into the BIOS to look at anything. All the connections to the PSU are snug as well. The QVL for this motherboard says that the RAM is compatible, although I read that Ryzen can be picky when it comes to RAM.
Could this be an issue with the CPU or GPU? Maybe the motherboard itself? I suppose I would have to take everything out of the case to thoroughly bench test the components, right? Any help or suggestions would be greatly appreciated. This is my first build so I am still fairly new to this.
