Overclocked i5 2500k and battlefield 3 problem
pinhead12345
52
Hi all.
Im having a little problem with my overclocked i5 2500k.
I have it overclocked to 4.5ghz with voltage set to auto on the mobo and bclk set to 100mhz. (mobo is gigabyte ga-z68xp-ud4)
Now I have used intel burn test and ran 20 test @ high and the temps are 55-60c and it is stable, i have also ran prime 95 for hours and hours and all is stable.
The problem comes when playing battlefield 3, if i leave the cpu at stock settings there is no problem but when it is overclocked for some annoying reason the computer will freeze completely and i have to do a hard reset and then I get an error when it boots back up and the code I get is Bbcode 124.
I am lost for any ideas as to the problem due to IBT and prime running fine and stable but BF3 just does not like overclock and it is not stable with that game, but please remember when cpu is at stock settings bf3 never crashes for me.
Any ideas?
Cryosis00
52
Your error code is hardware related. You say it only occurs when you OC so I would tend to think you have an incorrect bios setting that is causing the hard lock.
Please list your complete hardware specs such as ram and graphics card.
Your temps look fine but I do not like auto voltage settings when OCing. Run HWMonitor when you run Prime95 and tell us when your max voltage is to the cpu.
pinhead12345
52
Thanks for the reply
i5 2500k
H60 Corsair Water Cooler
Gigabyte GA-Z68XP-UD4
Corsair Vengence 4 2GB STICKS
Sapphire 6950 2gb Crossfire
XFX 850W pro 70 AMP power supply
MAX CORE VOLTAGE IS 1.296v and as I have said it is stable with prime 95 and IBT ect but play an hour of battlefield 3 and it locks up. Put the settings back to stock in the bios so that the cpu is at stock and battlefield 3 runs fine.
Regards
Cygnus x-1
901
What's your QPI/Dram voltage set too. It could be cpu voltage, but at the frequency, it could easily be QPI voltage that needs to be raised. Also since you're prime stable, and freeze in game, I think that points to the memory controller/ram.
pinhead12345
52
Im not sure now how to proceed. Any guidance would be appricated.
I have read many stickies on this forum and other places on the net but not sure how to go about getting a safe overclock on my system as the last thing i want to do i blow up my mobo and cpu.
The board is a gigabyte ga-z68-ud4 rev 1.0
memory is corsair vengance 4 2gb sticks (8gb total) and i will post in a few hours the exact spec of the memory
I want the overclock at 4.5ghz
I have set the bckl at 100mhz and turned off spead spectrum at it was showing in cpuz as 99.8mhz bckl but still fluctuates between 99.8mhz - 100mhz
I set the voltage to auto
changed the cpu multiplier to x45
left everything else untouched (auto or default settings)
pinhead12345
52
btw will add that the voltage when on auto was showing 1.296v when cpu underload and prime and ibt was stable but bf3 would crash @ 4.5ghz
Also I have read that there are 2 ways of overclocking it...
a) set multiplier to 45
b) set each core to 45
which one would be the best and safest for 24/7 overclock????
Pity this noob :)
pinhead12345
52
Thanks for the reply!
I will look in to that page in detail tomorrow morning once I have slept and will report back.. Been up for 34 hours now so everything is becoming a blur and probably not a good idea to play in the bios when I am sleep deprived lol.
One thing I did notice is there are so many schools of thought regarding the best way to overclock and what people deam as a safe voltage for 24/7 use so it can get very confusing as im not sure what is the right course of action.
Right off to bed and be on in the morning.
Cheers
Pin
