Hello, First time posting here so please bare with me,
I'm having issue with Cooling, I have an i9 11900k which has an idle temp of 50° Celsius, any time I open a game it instantly spikes to 97-100° Celsius,with a max cou usage of 11%, which I believe I shouldn't be getting these temps with low cpu usage (right?) , ive tried changing the cooler
I've tried
Noctua u9s
H150i elite
Lian li galahad sl 360 (currently installed)
I've tried multiple programs to (stress) test
When trying cinibench temps maxed out at 55°
As it stands I feel at a loss with this pc, ill drop specs down below any advise is hugely appreciated
Oh one last thing, I have a temp gun, the exhaust fans/radiator showed max temp of 47°, In take was 38°, the weird part was the cpu only showed 50° (how reliable this is i'm not sure )
(ADDED NOTE)
I only play fivem and sea of theievs not on max settings, also it seems that playing these games i never go over 11%usage on cpu
(IMAGE LINKS)
View: https://i.imgur.com/Dk6xVKh.png
View: https://i.imgur.com/5yHhCUF.png
• CASE: Lian Li PC-O11 Dynamic Black Mid-Tower Dual Chamber Gaming Chassis
• CPU: Intel® Core™ i9-11900K - 8-Core 3.50GHz, 5.10GHz Turbo - 16MB Cache + UHD Graphics, Ultimate OC Compatible
• CS_FAN: 6x Corsair SP120 Elite Addressable RGB Fan Kit
• FAN: Lian Li galahad sl 360mm + 3x 3x unifan sl 120mm
• MEMORY: 32GB (4x8GB) DDR4/3200mhz Dual Channel Memory Corsair Vengeance Pro RGB w/Heat Spreader
• MOTHERBOARD: MSI MAG Z590 Tomahawk WIFI: ATX w/ Wi-Fi 6E, USB 3.2, 3x M.2
• POWERSUPPLY: Corsair RM850 850W 80+ Gold Modular Gaming Power Supply
• SSD: 480GB WD Green 2.5" SSD - 545MB/s Read / 465MB/s Write
• VIDEO: MSI GeForce® RTX 3070 Ti Gaming X Trio 8GB - Ray Tracing Technology, DX12®, VR Ready, HDMI, DP - 4 MIN. Monitor Support
I've tried
Noctua u9s
H150i elite
(ADDED NOTE)
(IMAGE LINKS)
