P4P800-E - fan monitor fluctuations
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I RMA'ed a P4P800-E Deluxe, the PSU connector
wouldn't allow the power cable to lock down, and
the serial port was screwy, 2 different external modems
wouldn't work on it.
On the replacement board, same BIOS revision 1002.002
The CPU, chassis & power fan monitors in
Asus Probe & AI keep fluctuating wildly.
The CPU temp will occasionally drop to 0,
other weird readings.
Any clues about what the problem is?
The CPU temps on this board are 3-4C higher than
on the board it replaced. 38-50C, the other
board ran 34-48C
P4P800-E DELUXE
P4/2.8EGHz 800M
1GB (2x512) Geil Dual Channel PC3200
Thermaltake 420 watt PurePower
WD 80 GB IDE
Apollo Geforce MX-440 64MB AGP
Johnny Asia, Guitarist from the Future
http://johnnyasia.info
"When a man describes himself as a "guitarist from
the future" the warning bells go off,
.... But Johnny Asia really sounds like he's doing
something new. .....Check the mans' music out
and hear something different."
- Nick Dedina, Staff Writer, Listen.com
Never mind, I discovered the power connector to the
floppy drive was loose. All is OK now.
The CPU idles 1C cooler now too. 37C instead of 38C
>board ran 34-48C
>P4P800-E DELUXE
>P4/2.8EGHz 800M
>WD 80 GB IDE
