Question PC boots into BIOS if I dont use it for 2 to 3 days, but works fine (boots into windows) if I use it daily. Note: I unplug my PC from power socket.
Nov 7, 2023
5
built my PC new, around 2 months back and it worked fine till now, this weird issue is occurring since a week or two. I highly doubt if its CMOS battery.
Windows 10 64 Bit. UEFI. CSM is disabled. Boot priority is set to Windows Boot Manager first.
Motherboard: Gigabyte B550M-K (BIOS: F1)
Processor: Ryzen 5 5600
RAM: Tforce Delta 8GBx2
GPU: NVIDIA GEFORCE RTX 3070
NVME: Lexar 500GB
SATA SSD: Team Group 1 TB
Initially the CSM was not disabled. And it worked fine, and one day it gave me an error "reboot and select proper boot device or insert boot media in selected boot device and press a key", again, I just used to reboot my PC and it worked fine (booted into windows), my vendor told me to disable CSM. But since when I've disabled CSM, it doesn't give me this error, but boots into BIOS if I dont use my PC for 2 to 3 days (yes, it remains unplugged) and "reboot and select proper boot device' error also occurred only when PC stayed unplugged for more than 1 or 2 days. Weird! Help please.
NVME: Lexar 500GB
Change the bios bat.......their cheap.
I changed the CMOS battery yesterday. Using Panasonic Lithium CR2032 now. I replaced the battery and tested twice after unplugging. Both the times PC booted successfully into windows. Checked on intervals of 3 hours and 13 hours. It's fine till now so far.
But I will update you after a week of testing. Let's see.
