Hey guys, so im building a PC and i wondered if this is a good build for 1080p 144hz/1440p 60fps Ultra gaming? Im open to suggestions too. I play mainly FFXIV and i want to be future proof for atleast 2 years coming:
CPU: AMD Ryzen 7 3700X (8x 3.6GHz / 4.4GHz Turbo)
Cooler: be quiet! Dark Rock 4
Motherboard: MSI B450 GAMING PRO CARBON AC
RAM: 16GB (2x8GB) G.Skill RipJaws V DDR4 3200MHz
SSD: 250GB SAMSUNG 970-EVO Plus M.2 PCIe 3.0 x4 (L 3500MB/s ; S 2300M
HDD: 2000GB SATA 6GB/s 5400rpm WD Blue WD20EZRZ
GPU: 8GB MSI RTX2070Super Ventus OC
PSU: 650W be quiet! Straight Power 11
Also adding the question, should i go for the MSI RTX 2070 Super Ventur OC or the KFA RTX 2070 Super EX? Is there a difference in like temperature or noise or performance between those two? The Super EX is around 40 bucks cheaper where im from.
Thank you for reading
