[SOLVED] PC freezes and screen goes dark and fans get louder
ExplicitArgo
5
Like the title says my pc freezes when I play games but only certain games (although is the vast majority, for example portal 2 freezes but RDR2 runs indefinitely) and when it freezes it either stays on the freeze image or the screen goes black and the case and cpu fans get rlly loud until I'm forced to press the power button which shuts it down immediately.
My build:
i5-9700K
msi Z390 gaming pro carbon atx mobo
32gb corsair vengeance rgb
msi geforce rtx 2060 super
evga BQ 750w 80+ bronze semi modular psu
Things I've tried:
Replacing the gpu (with the same card but a new one)
removing ram
bios updates
gpu driver updates
I've also checked temps before the crash happens and they seem to be ok
At this point I dont know what else to try and I really need help
Thank you.
How hot is your CPU getting while gaming?
Which 750W PSU did you try to replace the EVGA?
to have a look what the problem could be:
run userbenchmark.com and post the http link of your result, e.g. https://www.userbenchmark.com/UserRun/28977730
Reset the BIOS by jumper clrCMOS or JBAT or similar (eventually you will have to set the boot priority correctly after that)
check windows integrity
open the command prompt as administrator and type DISM /Online /Cleanup-Image /RestoreHealth
https://www.lifewire.com/how-to-open-an-elevated-command-prompt-2618088
https://answers.microsoft.com/en-us...em-files/bc609315-da1f-4775-812c-695b60477a93
clean...
My build:
i5-9700K
Things I've tried:
removing ram
bios updates
gpu driver updates
replaced psu with a brand new one (750w also)
My build:
i5-9700K
Things I've tried:
removing ram
bios updates
gpu driver updates
clean boot
https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows
check the memory by running memtest.org usb autoinstaller (bootable USB flash drive)
check the hard drive for errors with its manufacturer´s tool
use ddu uninstaller and reinstall the latest graphics driver
