Question PC hard-lock ups driving me insane
Dec 20, 2022
19
Hi all,
I am seeking some assistance from the tom's Hardware collective please to stop me going insane!
First I guess the info of the system:
Windows 10 Pro, build 19044 (up to date)
I9 9900K, not overclocked - bios all default settings / auto
2x8GB Corsair DDR4 2132 w/XMP @ 3596 - non XMP profile loaded
MSI Z390 Gaming Pro Carbon
Nvidia 3090Ti FE
1000w EVGA 80+ modular PSU
Crucial CT250 MX200 SSD for Operating System
Corsair MP600 Core 2TB SSD for game installs
2x WD 2TB standard HDDs
Widescreen 2560x1080 (so not many pixles!)
Quest 2 @ 1.6x SS / 90hz
I built this system around Jan 2022 (originally with my titan XP, then upgraded to 3090ti later in the year).
My issues started not long after building the PC, I purchased BF2042, and when I was playing the game, I experienced random locking up of the PC, with no mini dump, or system errors, only buttoning and rebooting would free up the PC.
I could play a game sometimes for 2 hours or so, other times maybe I couldn’t even play a single round and the PC would lockup.
At this time I had XMP profile loaded, and was running a titan XP. I have only experienced one other lockup, and that was after around 3-4 hours of Warzone, but mostly, all games run OK.
Fault finding:
Re-installed game
Tweaked XMP profile, as notice manufacturer timings differed to what bios was recommending, but still locked up
Removed XMP and set to default speed
Reset bios / CPU settings all to default and auto
Ran numerous OCCT tests, RAM and CPU tests passed
Conducted GPU stress tests with furmark - all passed
Memcheck – passed
Thermals checked – all good (CPU rarely more than mid 60’s, GPU same)
OCCT power test (crashed / locked after around 3 hours)
Checked 3.3v, 5v and 12v for any instability (only via software OCCT) – all good
Underclocked GPU RAM and core clock / reduced power target
Removed / reinstalled GPU drivers
Scanned all HDDs / checked for errors
Fresh install of Windows 10
Added Corsair NVME and fresh install of all game to a new / different HDD
Swapped PSU power connectors to GPU
Have since changed GPU to 3090ti
When the machine locks up, it is often during title screen, loading, after game, although can happen during game.
During last lockup:
CPU @ 49% utilisation
CPU package temp 57c
RAM @ 12GB usage
Disk 0, 1, 2 @ 0% (disk 0 OS volume)
Disk 3 @ 5% (game SSD)
Ethernet usage high-ish 344kbps
GPU usage 11%
GPU power 27%
VRAM 6579mb
GPU temp 53c
There is never anything in the event log I can see other than unexpected shutdowns / kernel power caused by me buttoning.
I also play VR, and I run @ 1.6SS, so that is 5408x2736, this depends on title but according to EVGA my GPU usage can vary from 60ish up to 90% or so. I play Project cars for hours, no problem, and other games such as Alyx, utilising over 16GB VRAM and with high GPU utilisation with no crashing.
The only needle I can find is that last night, on one of the crashes I sat and waited (I have before for a long time and never a BSOD or error), one of my screens went almost black and I did get a BSOD!) now this may be a coincidence, but anyway it was ‘DPC WATCHDOG VIOLATION’ and I had at least a dump file:
On Mon 19/12/2022 21:35:01 your computer crashed or a problem was reported
Crash dump file: C:\WINDOWS\Minidump\121922-8828-01.dmp (Minidump)
Bugcheck code: 0x133(0x1, 0x1E00, 0xFFFFF805758FB320, 0x0)
Bugcheck name:DPC_WATCHDOG_VIOLATION
Driver or module in which error occurred: aswVmm.sys (aswVmm+0x28363)
File path:C:\WINDOWS\system32\drivers\aswVmm.sys
Bug check description:The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL or above. This could be caused by either a non-responding driver or non-responding hardware. This bug check can also occur because of overheated CPUs (thermal issue).
Analysis:This is likely caused by a hardware problem, but there is a possibility that this is caused by a misbehaving driver.
This bugcheck indicates that a timeout has occurred. This may be caused by a hardware failure such as a thermal issue or a bug in driver for a hardware device.
Read this article on thermal issues
A full memory dump will likely provide more useful information on the cause of this particular bugcheck.
Google query:aswvmm DPC_WATCHDOG_VIOLATION
Crash dump file: C:\WINDOWS\MEMORY.DMP (Kernel memory dump)
So I removed and cleaned AVG in safe mode – still had a lock up in BF2042.
When this BSOD was generated thermals were fine, I want to add that on custom settings in BF with everything on ultra, and all additional settings enable, my GPU rarely goes about 38%, so GPU temps in BF are normally in the 50’s or lower, and CPU never goes over mid 60’s.
Windows debugger tells a slightly different story though?
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 19041 MP (16 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Edition build lab: 19041.1.amd64fre.vb_release.191206-1406
Machine Name:
Kernel base = 0xfffff80574c00000 PsLoadedModuleList = 0xfffff8057582a2b0
Debug session time: Mon Dec 19 21:35:01.932 2022 (UTC + 0:00)
System Uptime: 4 days 21:29:46.062
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff80574ff92d0 48894c2408 mov qword ptr [rsp+8],rcx ss:ffffbd01de692e20=0000000000000133
3: kd> !analyze -v
  • Bugcheck Analysis *
DPC_WATCHDOG_VIOLATION (133)
or above.
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
Arg2: 0000000000001e00, The watchdog period (in ticks).
Arg3: fffff805758fb320, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
additional information regarding the cumulative timeout
Arg4: 0000000000000000
Debugging Details:
* Either you specified an unqualified symbol, or your debugger *
* doesn't have full symbol information. Unqualified symbol *
* resolution is turned off by default. Please either specify a *
* fully qualified symbol module!symbolname, or enable resolution *
* of unqualified symbols by typing ".symopt- 100". Note that *
* enabling unqualified symbol resolution with network symbol *
* server shares in the symbol path may cause the debugger to *
* appear to hang for long periods of time when an incorrect *
* symbol name is typed or the network symbol server is down. *
* For some commands to work properly, your symbol path *
* must point to .pdb files that have full type information. *
* Certain .pdb files (such as the public OS symbols) do not *
* contain the required information. Contact the group that *
* provided you with these symbols if you need this command to *
* work. *
* Type referenced: TickPeriods *
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 3749
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 4088
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 249
Key : Analysis.Init.Elapsed.mSec
Value: 3917
Key : Analysis.Memory.CommitPeak.Mb
Value: 86
Key : Bugcheck.Code.DumpHeader
Value: 0x133
Key : Bugcheck.Code.Register
Value: 0x133
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Timestamp
Value: 2019-12-06T14:06:00Z
Key : WER.OS.Version
Value: 10.0.19041.1
FILE_IN_CAB: 121922-8828-01.dmp
BUGCHECK_CODE: 133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff805758fb320
BUGCHECK_P4: 0
DPC_TIMEOUT_TYPE: DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED
TRAP_FRAME: ffffe403cb271ee0 -- (.trap 0xffffe403cb271ee0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000001 rbx=0000000000000000 rcx=00000000003506f8
rdx=00000000000c00e1 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80574ebb970 rsp=ffffe403cb272070 rbp=0000000000000003
r8=000000000000082f r9=00000000000000e1 r10=fffff80574f376e0
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe nc
nt!KiIpiSendRequestEx+0xb0:
fffff80574ebb970 8b87802d0000 mov eax,dword ptr [rdi+2D80h] ds:0000000000002d80=????????
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: BF2042.exe
STACK_TEXT:
ffffbd01de692e18 fffff8057505bf02 : 0000000000000133 0000000000000001 0000000000001e00 fffff805758fb320 : nt!KeBugCheckEx
ffffbd01de692e20 fffff80574ed2973 : 00001796ea01adaf ffffbd01de640180 0000000000000000 ffffbd01de640180 : nt!KeAccumulateTicks+0x186d32
ffffbd01de692e80 fffff80574ed245a : ffffd30b342b6d40 ffffe403cb271f60 0000000000000000 ffff87000beb4d02 : nt!KeClockInterruptNotify+0x453
ffffbd01de692f30 fffff80574e08a45 : ffffd30b342b6d40 fffff80574f545e7 0000000000000000 0000000000000000 : nt!HalpTimerClockIpiRoutine+0x1a
ffffbd01de692f60 fffff80574ffb26a : ffffe403cb271f60 ffffd30b342b6d40 0000000000000001 0000000000000000 : nt!KiCallInterruptServiceRoutine+0xa5
ffffbd01de692fb0 fffff80574ffba37 : 00000000d79761d4 ffffbd01de643088 ffffe403cb272011 0000000000000003 : nt!KiInterruptSubDispatchNoLockNoEtw+0xfa
ffffe403cb271ee0 fffff80574ebb970 : 0000000000000028 fffff80574ebd2e9 0000000000000001 0000000000000000 : nt!KiInterruptDispatchNoLockNoEtw+0x37
ffffe403cb272070 fffff80574eda8ac : 0000000000000000 0000000000000002 0000009000000000 ffff8a0000007000 : nt!KiIpiSendRequestEx+0xb0
ffffe403cb2720b0 fffff80574eda5eb : 0000000000000004 0000000000000000 0000000003800000 0000000000000002 : nt!KxFlushEntireTb+0x1bc
ffffe403cb272100 fffff80574e86592 : 0000000000000000 0000000000000000 0000000000000000 fffff80575850b00 : nt!KeFlushTb+0x7b
ffffe403cb272160 fffff80574e888d1 : 0000000000000000 0000000000000000 ffff87000beb4d40 ffff87000beb4d40 : nt!MiFlushEntireTbDueToAttributeChange+0x3a
ffffe403cb272250 fffff80574e3ffd5 : 8a000003f919c96b 0000000000000001 ffff87000beb4d62 0000000000000000 : nt!MiChangePageAttributeBatch+0x91
ffffe403cb2722c0 fffff80574e3cd58 : ffffe403cb272690 0000000000000000 0000000000000001 0000000000000000 : nt!MiGetPageChain+0xd75
ffffe403cb272500 fffff80574e3c2a8 : ffffe403cb272690 ffffe403cb2728e0 ffffd30b00000000 0000000000000000 : nt!MiResolvePrivateZeroFault+0x6e8
ffffe403cb272630 fffff80574e3b67d : 00000000c0000016 0000000000000002 0000000000000000 0000000000000002 : nt!MiResolveDemandZeroFault+0x208
ffffe403cb272720 fffff80574e39769 : 0000000000000111 0000000000000004 00000000c0000016 0000000000000000 : nt!MiDispatchFault+0x22d
ffffe403cb272860 fffff80575008dd8 : 000000004e71d084 ffffe403cb272a80 000000004e71d098 0000000000000001 : nt!MmAccessFault+0x189
ffffe403cb272a00 00000001422cc1fc : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : nt!KiPageFault+0x358
000000004e718f60 0000000000000000 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : 0x00000001`422cc1fc
SYMBOL_NAME: nt!KeAccumulateTicks+186d32
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
IMAGE_VERSION: 10.0.19041.2251
STACK_COMMAND: .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET: 186d32
FAILURE_BUCKET_ID: 0x133_ISR_nt!KeAccumulateTicks
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {65350307-c3b9-f4b5-8829-4d27e9ff9b06}
Followup: MachineOwner
In a last ditch attempt at anything meaningful, I noticed some DPC watchdog errors related to iastora.sys, and so re-installed the driver for the OS SSD, but you guessed it, still several lockups this evening, resulting in me buttoning the PC and no dump files, nothing I can see being meaningful in event viewer.
I am now leaning towards a PSU issue, it is after all, 7 years old now! However, if BF2042 is taxing my system less overall than running 14 million pixels in VR, and drawing a hell of a lot more power, how can it be stable there and fall over when ticking over in BF2042?
The PSU is a single rail, but I am not familiar with how the CPU / mobo circuit works vs PCIE and HDD supply.
My other thoughts were HDD, but the OS HDD although also an older crucial drive from a previous build seems reliable – no vanishing files, no corrupt files or weirdness, no errors.
With power ‘appearing’ stable in VR and OCCT tests I am not sure.
Perhaps I got a dodgy stick of RAM, but memtest checks out, and OCCT memory tests always seem to work just fine using 95% of memory.
Maybe I got a dodgy CPU? But a CPU burn or stress test at 100% also seems stable (I’ve done more memory and CPU tests this eve on OCCT and all good, no errors).
So then motherboard? But again, seems to be OK?
I will check my motherboard bios, but I am pretty sure when these crashes started it was also up to date at the time, although another release may be out now.
So here I am, I have a PC with all ‘new’ parts in this build other than OS HDD and old PSU. But it would be great to actually pin point the issue without throwing money at something that doesn’t need replacing.
My only other thought is to perhaps play with the CPU voltage, it runs at 1.286v max on auto, with package power around 117w. Temperatures aren’t an issue, so did I get a bad one that just needs more juice to run stable at the stock 4.68? Again if that is the case wouldn’t this manifest in VR?
Pretty much stumped guys, and if you’ve made it this far well done, and thanks for reading.
Seriously welcome any ideas / testing I can do to pin this one down.
Thanks.
I recommend using spoilers for long text like this.
I cannot see anything in the details that gives any clue, but if you can post the s.m.a.r.t. data of the storage devices (can use crystaldiskinfo - copy all to text and then paste reply here - use code tags) maybe it give some hints. A non-responding storage device may cause OS to not respond either.
Reactions: Steveoz32
So your crucial mx200 has been hosting windows 10 the entire year?
I suspect a drive too
Well you have the 2tb corsair nvme why didn't you simply install the os on that you have 4tb of hdd storage so a 250gb ssd is basically a piece of junk that you probably don't even really need attached to your system anyway.
So stash any data on the 2tb corsair on your hard disk drive, and copy your my docs from your crucial windows disk to keep saved games data, to a hdd too, and what else you want to keep, docs, pics, emails, whatever, and for the moment disconnect all other drives, sata and power cables, and run a clean install with only the corsair disk attached.
So now we're testing the system with only the corsair nvme drive installed. After you have completed windows setup you can reconnect your hdd's if you want to reload some games from backup or something .
See what happens.
I note that your corsair 2tb is pci-e nvme is gen 4 while your mobo supports gen 3 - not a problem since gen 4 is backwards compatible with gen 3 only it doesn't run full speed is all it wouldn't cause it to crash or any problems.
So it might just be that crucial mx it is an honest to god cheap lo end 2.5inch sata 3 ssd and likely you could easily buy a duff one off the shelf. Yet somehow you have also managed to workaround this glitching out for the best part of a year - not judging but that's a bit mind boggling. I flip if I get one bsod let alone a series of crashes.
Besides that any reason you didn't upgrade to windows 11? If you haven't done so already, register a microsoft account to your pc and so you get the digital license and you should be eligible for a windows 11 upgrade which you can do once this glitch has been figured out.
There's no technical reason not to do it and windows 11 has had some of the kinks worked out by now too - there were some gaming stuttering issues but that was I think affecting higher end systems anyway with the newest gen cpus so probably nothing you need to worry about.
There's also a few howtos and guides hidden away in various sections of the forum - just start on the main page of the forums and there'll be guides in each section just stuff to brush up on.
Particularly the power supplies section of the forum. Could you be a bit more specific of the exact model of your 1000w Evga 80+ - read the label or link the page/site you bought it from so it can be checked against the psu tier list
It's wattage is enough for a 3090 but the quality might not be tier a.
So the main suspect is simply the crucial mx200 it's simply a lo end drive hosting your os if that glitches, of course it would cause the system to crash.
Just means you have to faff around stashing windows stuff like saved games and data that might be stored in your user profile before you disconnect it. For the moment you can simply disconnect the disk, without deleting anything, add it back later but obviously you'll need to remove it from boot priorities in the bios so it doesn't load instead of your fresh install on the corsair nvme drive.
Just to check you could also re-connect each of your sata drives one at a time and road testing them by running a game on them, but if it was the drive hosting the os causing the problem it shouldn't crash with windows hosted on the corsair nvme so you should be able to reconnect all your drives without it crashing anyway.
I'm pretty sure when you get a dead drive only windows explorer crashes when you try to access it rather than bringing down the entire system but I've only had that happen occasionally ages ago on some really old drives.
Thanks. I've copied it out. I'm mistaken, I pulled one of the 2TBs a while ago and stuck it into another machine, so this has 1x2tb and 1x500gb older drive just to store photos and stuff on, but still 4x drives in the system 3x sata and 1x pcie.
Cheers,
Code:
CrystalDiskInfo 8.17.13 (C) 2008-2022 hiyohiyo
                                Crystal Dew World: https://crystalmark.info/
    OS : Windows 10 Professional [10.0 Build 19045] (x64)
  Date : 2022/12/21 23:39:13
-- Controller Map ----------------------------------------------------------
+ Standard SATA AHCI Controller [ATA]
   - ST3500418AS
   - Crucial_CT250MX200SSD1
   - Generic IEEE 1667 Probe Silo
   - Microsoft TCG Storage silo
   - Generic IEEE 1667 ACT
   - WDC WD20EZRX-00DC0B0
+ Standard NVM Express Controller [SCSI]
   - Corsair MP600 CORE
- Microsoft Storage Spaces Controller [SCSI]
- Xvdd SCSI Miniport [SCSI]
+ Virtual CloneDrive [SCSI]
   - ELBY CLONEDRIVE SCSI CdRom Device
-- Disk List ---------------------------------------------------------------
(01) ST3500418AS : 500.1 GB [0/0/0, pd1]
(02) Crucial_CT250MX200SSD1 : 250.0 GB [1/0/0, pd1] - mi
(03) WDC WD20EZRX-00DC0B0 : 2000.3 GB [2/0/0, pd1]
(04) Corsair MP600 CORE : 2000.3 GB [3/1/0, sq] - nv
(01) ST3500418AS
           Model : ST3500418AS
        Firmware : CC38
   Serial Number : 6VMCXKEL
       Disk Size : 500.1 GB (8.4/137.4/500.1/500.1)
     Buffer Size : 16384 KB
     Queue Depth : 32
    # of Sectors : 976773168
   Rotation Rate : 7200 RPM
       Interface : Serial ATA
   Major Version : ATA8-ACS
   Minor Version : ATA8-ACS version 4
   Transfer Mode : ---- | SATA/300
  Power On Hours : 9714 hours
  Power On Count : 5111 count
     Temperature : 30 C (86 F)
   Health Status : Good
        Features : S.M.A.R.T., AAM, NCQ, GPL
       APM Level : ----
       AAM Level : FE00h [ON]
    Drive Letter : E:
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 111 _99 __6 000001C2B335 Read Error Rate
03 _97 _97 __0 000000000000 Spin-Up Time
04 _87 _87 _20 00000000366F Start/Stop Count
05 100 100 _36 000000000000 Reallocated Sectors Count
07 _66 _60 _30 0000003D9596 Seek Error Rate
09 _89 _89 __0 0000000025F2 Power-On Hours
0A 100 100 _97 000000000000 Spin Retry Count
0C _96 _37 _20 0000000013F7 Power Cycle Count
B7 100 100 __0 000000000000 Vendor Specific
B8 100 100 _99 000000000000 End-to-End Error
BB 100 100 __0 000000000000 Reported Uncorrectable Errors
BC 100 _92 __0 000100010011 Command Timeout
BD 100 100 __0 000000000000 High Fly Writes
BE _70 _60 _45 00001E1D001E Airflow Temperature
C2 _30 _40 __0 000A0000001E Temperature
C3 _30 _12 __0 000001C2B335 Hardware ECC recovered
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
C7 200 195 __0 00000000007D UltraDMA CRC Error Count
F0 100 253 __0 F1D3000065FD Head Flying Hours
F1 100 253 __0 0000D564173F Total Host Writes
F2 100 253 __0 000093C81F8E Total Host Reads
-- IDENTIFY_DEVICE ---------------------------------------------------------
        0    1    2    3    4    5    6    7    8    9
000: 0C5A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2020 2020 2020 2020 3656 4D43 584B 454C
020: 0000 8000 0004 4343 3338 2020 2020 5354 3335 3030
030: 3431 3841 5320 2020 2020 2020 2020 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 0506 0000 0048 0040
080: 01F0 0029 346B 7F01 4163 3469 BE01 4163 017F 0027
090: 0027 0000 FFFE 0000 FE00 0000 0000 0000 0000 0000
100: 6030 3A38 0000 0000 0000 0000 0000 0000 5000 C500
110: 2232 A739 0000 0000 0000 0000 0000 0000 0000 401E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 6030
130: 3A38 6030 3A38 2020 0002 0140 0100 5000 3C06 3C0A
140: 0000 003C 0000 0008 0000 0000 004F 0280 0000 0000
150: 0008 0000 0000 0000 0000 0000 0000 0000 3F00 9800
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 103F 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000
220: 0000 0000 1010 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 3AA5
-- SMART_READ_DATA ---------------------------------------------------------
     +0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 0A 00 01 0F 00 6F 63 35 B3 C2 01 00 00 00 03 03
010: 00 61 61 00 00 00 00 00 00 00 04 32 00 57 57 6F
020: 36 00 00 00 00 00 05 33 00 64 64 00 00 00 00 00
030: 00 00 07 0F 00 42 3C 96 95 3D 00 00 00 00 09 32
040: 00 59 59 F2 25 00 00 00 00 00 0A 13 00 64 64 00
050: 00 00 00 00 00 00 0C 32 00 60 25 F7 13 00 00 00
060: 00 00 B7 32 00 64 64 00 00 00 00 00 00 00 B8 32
070: 00 64 64 00 00 00 00 00 00 00 BB 32 00 64 64 00
080: 00 00 00 00 00 00 BC 32 00 64 5C 11 00 01 00 01
090: 00 00 BD 3A 00 64 64 00 00 00 00 00 00 00 BE 22
0A0: 00 46 3C 1E 00 1D 1E 00 00 00 C2 22 00 1E 28 1E
0B0: 00 00 00 0A 00 00 C3 1A 00 1E 0C 35 B3 C2 01 00
0C0: 00 00 C5 12 00 64 64 00 00 00 00 00 00 00 C6 10
0D0: 00 64 64 00 00 00 00 00 00 00 C7 3E 00 C8 C3 7D
0E0: 00 00 00 00 00 00 F0 00 00 64 FD FD 65 00 00 D3
0F0: F1 10 F1 00 00 64 FD 3F 17 64 D5 00 00 00 F2 00
100: 00 64 FD 8E 1F C8 93 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 82 00 58 02 00 7B
170: 03 00 01 00 01 54 02 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 80 01 00 00 06 03 03 03 03 03 03 03
190: 03 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 1E 07 51 EC D2 1F 00 00
1B0: 00 00 00 00 01 00 74 00 3F 17 64 D5 AB 0B 00 00
1C0: 8E 1F C8 93 A8 19 00 00 00 00 00 00 28 17 F3 09
1D0: 00 00 03 03 00 00 00 00 7E 01 00 00 26 00 04 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 37
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B9
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 01 00 01 06 00 00 00 00 00 00 00 00 00 00 03 00
010: 00 00 00 00 00 00 00 00 00 00 04 14 00 00 00 00
020: 00 00 00 00 00 00 05 24 00 00 00 00 00 00 00 00
030: 00 00 07 1E 00 00 00 00 00 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 61 00 00 00 00
050: 00 00 00 00 00 00 0C 14 00 00 00 00 00 00 00 00
060: 00 00 B7 00 00 00 00 00 00 00 00 00 00 00 B8 63
070: 00 00 00 00 00 00 00 00 00 00 BB 00 00 00 00 00
080: 00 00 00 00 00 00 BC 00 00 00 00 00 00 00 00 00
090: 00 00 BD 00 00 00 00 00 00 00 00 00 00 00 BE 2D
0A0: 00 00 00 00 00 00 00 00 00 00 C2 00 00 00 00 00
0B0: 00 00 00 00 00 00 C3 00 00 00 00 00 00 00 00 00
0C0: 00 00 C5 00 00 00 00 00 00 00 00 00 00 00 C6 00
0D0: 00 00 00 00 00 00 00 00 00 00 C7 00 00 00 00 00
0E0: 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00
0F0: 00 00 F1 00 00 00 00 00 00 00 00 00 00 00 F2 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60
           Model : Crucial_CT250MX200SSD1
        Firmware : MU01
   Serial Number : 15030E69F8A7
       Disk Size : 250.0 GB (8.4/137.4/250.0/250.0)
     Buffer Size : Unknown
     Queue Depth : 32
    # of Sectors : 488397168
   Rotation Rate : ---- (SSD)
   Major Version : ACS-3
   Minor Version : ACS-3 Revision 4
   Transfer Mode : SATA/600 | SATA/600
  Power On Hours : 11261 hours
  Power On Count : 2576 count
     Host Writes : 23419 GB
     Temperature : 32 C (89 F)
   Health Status : Good (90 %)
        Features : S.M.A.R.T., APM, NCQ, TRIM, DevSleep, GPL
       APM Level : 00FEh [ON]
       AAM Level : ----
    Drive Letter : C:
01 100 100 __0 000000000000 Raw Read Error Rate
05 100 100 __0 000000000000 Reallocated NAND Blocks
09 100 100 __0 000000002BFD Power On Hours
0C 100 100 __0 000000000A10 Power Cycle Count
AB 100 100 __0 000000000000 Program Fail Count
AC 100 100 __0 000000000000 Erase Fail Count
AD _90 _90 __0 000000000137 Average Block-Erase Count
AE 100 100 __0 00000000006F Unexpected Power Loss Count
B4 __0 __0 __0 000000000A1B Unused Reserve NAND Blocks
B7 100 100 __0 000000000000 SATA Interface Downshift
B8 100 100 __0 000000000000 Error Correction Count
C2 _68 _43 __0 0039000D0020 Temperature
C4 100 100 __0 000000000000 Reallocation Event Count
C6 100 100 __0 000000000000 Smart Off-line Scan Uncorrectable Error Count
C7 100 100 __0 000000000000 Ultra DMA CRC Error Rate
CA _90 _90 __0 00000000000A Percent Lifetime Used
CE 100 100 __0 000000000000 Write Error Rate
D2 100 100 __0 000000000000 Successful RAIN Recovery Count
F6 100 100 __0 000B6F6F3A7C Total Host Sector Writes
F7 100 100 __0 00005B8ADDBB Host Program Page Count
F8 100 100 __0 00006AFE8BD0 Background Program Page Count
        0    1    2    3    4    5    6    7    8    9
000: 0440 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2020 2020 3135 3033 3045 3639 4638 4137
020: 0000 0000 0000 4D55 3031 2020 2020 4372 7563 6961
030: 6C5F 4354 3235 304D 5832 3030 5353 4431 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 4001 2F00
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB A110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 4DB8
070: 0000 0000 0000 0000 0000 001F 950E 00C6 016C 0040
080: 07F8 011B 7069 7409 6163 7069 B409 6163 017F 0000
090: 0000 00FE 0000 0000 0000 0000 0000 0000 0000 0000
100: 5970 1D1C 0000 0000 0000 0008 6003 0000 500A 0751
110: 0E69 F8A7 0000 0000 0000 0000 0000 0000 0000 411E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0000 4D55
130: 3031 2E30 342E 5330 0000 0000 0000 3336 3631 2020
140: 2020 3130 524E 3336 3631 2020 2020 4D54 4644 4441
150: 4B32 3530 4D42 4B20 0000 0000 0000 0000 0001 A5A5
160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0001
200: 0000 0000 0000 0000 0000 0000 0035 0000 0000 4000
210: 0000 0000 0000 0001 0000 0000 0000 0001 0000 0000
220: 0000 0000 10FF 0000 0000 0000 0000 0000 0000 0000
230: 5970 1D1C 0000 0000 0001 00FF 0000 0000 0000 0000
240: 0000 0000 0000 4000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 3FA5
000: 10 00 01 2F 00 64 64 00 00 00 00 00 00 00 05 33
010: 00 64 64 00 00 00 00 00 00 00 09 32 00 64 64 FD
020: 2B 00 00 00 00 00 0C 32 00 64 64 10 0A 00 00 00
030: 00 00 AB 32 00 64 64 00 00 00 00 00 00 00 AC 32
040: 00 64 64 00 00 00 00 00 00 00 AD 32 00 5A 5A 37
050: 01 00 00 00 00 00 AE 32 00 64 64 6F 00 00 00 00
060: 00 00 B4 33 00 00 00 1B 0A 00 00 00 00 00 B7 32
070: 00 64 64 00 00 00 00 00 00 00 B8 32 00 64 64 00
080: 00 00 00 00 00 00 BB 32 00 64 64 00 00 00 00 00
090: 00 00 C2 22 00 44 2B 20 00 0D 00 39 00 00 C4 32
0A0: 00 64 64 00 00 00 00 00 00 00 C5 32 00 64 64 00
0B0: 00 00 00 00 00 00 C6 30 00 64 64 00 00 00 00 00
0C0: 00 00 C7 32 00 64 64 00 00 00 00 00 00 00 CA 31
0D0: 00 5A 5A 0A 00 00 00 00 00 00 CE 0E 00 64 64 00
0E0: 00 00 00 00 00 00 D2 32 00 64 64 00 00 00 00 00
0F0: 00 00 F6 32 00 64 64 7C 3A 6F 6F 0B 00 00 F7 32
100: 00 64 64 BB DD 8A 5B 00 00 00 F8 32 00 64 64 D0
110: 8B FE 6A 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 80 00 1B 03 00 7B
170: 03 00 01 00 02 05 03 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5
000: 10 00 01 00 00 00 00 00 00 00 00 00 00 00 05 00
010: 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00
020: 00 00 00 00 00 00 0C 00 00 00 00 00 00 00 00 00
030: 00 00 AB 00 00 00 00 00 00 00 00 00 00 00 AC 00
040: 00 00 00 00 00 00 00 00 00 00 AD 00 00 00 00 00
050: 00 00 00 00 00 00 AE 00 00 00 00 00 00 00 00 00
060: 00 00 B4 00 00 00 00 00 00 00 00 00 00 00 B7 00
070: 00 00 00 00 00 00 00 00 00 00 B8 00 00 00 00 00
080: 00 00 00 00 00 00 BB 00 00 00 00 00 00 00 00 00
090: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C4 00
0A0: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00
0B0: 00 00 00 00 00 00 C6 00 00 00 00 00 00 00 00 00
0C0: 00 00 C7 00 00 00 00 00 00 00 00 00 00 00 CA 00
0D0: 00 00 00 00 00 00 00 00 00 00 CE 00 00 00 00 00
0E0: 00 00 00 00 00 00 D2 00 00 00 00 00 00 00 00 00
0F0: 00 00 F6 00 00 00 00 00 00 00 00 00 00 00 F7 00
100: 00 00 00 00 00 00 00 00 00 00 F8 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E
           Model : WDC WD20EZRX-00DC0B0
        Firmware : 80.00A80
   Serial Number : WD-WCC1T1053425
       Disk Size : 2000.3 GB (8.4/137.4/2000.3/2000.3)
     Queue Depth : 32
    # of Sectors : 3907029168
   Rotation Rate : Unknown
   Major Version : ACS-2
   Minor Version : ----
  Power On Hours : 14316 hours
  Power On Count : 3652 count
     Temperature : 29 C (84 F)
        Features : S.M.A.R.T., NCQ, GPL
       APM Level : ----
       AAM Level : ----
    Drive Letter : D:
01 200 200 _51 000000000000 Read Error Rate
03 181 176 _21 000000001725 Spin-Up Time
04 _94 _94 __0 0000000018CD Start/Stop Count
05 200 200 140 000000000000 Reallocated Sectors Count
07 200 200 __0 000000000000 Seek Error Rate
09 _81 _81 __0 0000000037EC Power-On Hours
0A 100 100 __0 000000000000 Spin Retry Count
0B 100 100 __0 000000000000 Recalibration Retries
0C _97 _97 __0 000000000E44 Power Cycle Count
C0 200 200 __0 0000000000BC Power-off Retract Count
C1 _66 _66 __0 000000062493 Load/Unload Cycle Count
C2 121 _93 __0 00000000001D Temperature
C4 200 200 __0 000000000000 Reallocation Event Count
C5 200 200 __0 000000000000 Current Pending Sector Count
C6 200 200 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
C8 200 200 __0 000000000000 Write Error Rate
        0    1    2    3    4    5    6    7    8    9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2057 442D 5743 4331 5431 3035 3334 3235
020: 0000 0000 0000 3830 2E30 3041 3830 5744 4320 5744
030: 3230 455A 5258 2D30 3044 4330 4230 2020 2020 2020
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0110
070: 0000 0000 0000 0000 0000 001F 970E 0006 004C 0040
080: 03FE 0000 746B 7D61 4123 7469 BC41 4123 017F 0086
090: 0086 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 88B0 E8E0 0000 0000 0000 0000 6003 0000 5001 4EE2
110: B340 1207 0000 0000 0000 0000 0000 0000 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0400
130: 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 70B5 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
220: 0000 0000 103E 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 8DA5
000: 10 00 01 2F 00 C8 C8 00 00 00 00 00 00 00 03 27
010: 00 B5 B0 25 17 00 00 00 00 00 04 32 00 5E 5E CD
020: 18 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
030: 00 00 07 2E 00 C8 C8 00 00 00 00 00 00 00 09 32
040: 00 51 51 EC 37 00 00 00 00 00 0A 32 00 64 64 00
050: 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00
060: 00 00 0C 32 00 61 61 44 0E 00 00 00 00 00 C0 32
070: 00 C8 C8 BC 00 00 00 00 00 00 C1 32 00 42 42 93
080: 24 06 00 00 00 00 C2 22 00 79 5D 1D 00 00 00 00
090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32
0A0: 00 C8 C8 00 00 00 00 00 00 00 C6 30 00 C8 C8 00
0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 00 00 00 00 00
0C0: 00 00 C8 08 00 C8 C8 00 00 00 00 00 00 00 00 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 82 00 E8 62 01 7B
170: 03 00 01 00 02 FF 05 00 01 00 00 00 00 00 00 00
180: 00 00 01 05 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 88
000: 10 00 01 33 C8 C8 C8 C8 C8 00 00 00 00 00 03 15
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
030: 00 00 07 00 C8 C8 C8 C8 C8 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00
070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
0C0: 00 00 C8 00 C8 C8 C8 C8 C8 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05
           Model : Corsair MP600 CORE
        Firmware : EGFM52.4
   Serial Number : 22027908000130374012
       Interface : NVM Express
        Standard : NVM Express 1.3
   Transfer Mode : PCIe 3.0 x4 | PCIe 4.0 x4
  Power On Hours : 240 hours
  Power On Count : 153 count
      Host Reads : 2816 GB
     Host Writes : 1996 GB
     Temperature : 51 C (123 F)
   Health Status : Good (100 %)
        Features : S.M.A.R.T., TRIM, VolatileWriteCache
    Drive Letter : G:
ID RawValues(6) Attribute Name
01 000000000000 Critical Warning
02 000000000145 Composite Temperature
03 000000000064 Available Spare
04 000000000005 Available Spare Threshold
05 000000000000 Percentage Used
06 0000005A238D Data Units Read
07 0000003FE320 Data Units Written
08 000000F72EC6 Host Read Commands
09 0000004728FE Host Write Commands
0A 00000000004A Controller Busy Time
0B 000000000099 Power Cycles
0C 0000000000F0 Power On Hours
0D 000000000012 Unsafe Shutdowns
0E 000000000000 Media and Data Integrity Errors
0F 0000000000E5 Number of Error Information Log Entries
        0    1    2    3    4    5    6    7    8    9
000: 1987 1987 3232 3230 3937 3830 3030 3130 3033 3733
010: 3034 3231 6F43 7372 6961 2072 504D 3036 2030 4F43
020: 4552 2020 2020 2020 2020 2020 2020 2020 2020 2020
030: 2020 2020 4745 4D46 3235 342E A701 6479 0900 0001
040: 0300 0001 9680 0098 9680 0098 0200 0000 0002 0000
050: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
060: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
070: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
080: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
090: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
100: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
110: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
120: 0000 0000 0000 0000 0000 0000 0000 0000 0017 0303
130: 0812 043E 0101 015C 0161 0064 0000 0000 0000 0000
140: 6000 C111 01D1 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 000A 0100
160: 0000 0001 0139 0157 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
220: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 0000
-- SMART_NVME --------------------------------------------------------------
000: 00 44 01 64 05 00 00 00 00 00 00 00 00 00 00 00
010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
020: 07 24 5A 00 00 00 00 00 00 00 00 00 00 00 00 00
030: 22 E3 3F 00 00 00 00 00 00 00 00 00 00 00 00 00
040: 62 2F F7 00 00 00 00 00 00 00 00 00 00 00 00 00
050: 9C 29 47 00 00 00 00 00 00 00 00 00 00 00 00 00
060: 4A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
070: 99 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
080: F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
090: 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0B0: E5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0D0: 00 00 00 00 00 00 00 00 03 00 00 00 01 00 00 00
0E0: 02 04 00 00 6A 04 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
See what happens.
Thanks, TBH, when I bought the crucial SSD (a long time ago!) it was pretty decent, it still has a faster write speed than most of the usual SATA SSDs. I did download crystal tools like advised and it has a health rating of 90%? Not sure what that means. I might copy the OS to the nvme and try that, or just buy a £30 SSD to save me formatting and reinstalling all my games to test if I can rule the SSD out.
S.M.A.R.T. info imo means diddly. It can't tell you everything. It means more in very intensive applications in an industrial park most home users simply can't wear out the nand before the warranty expires no matter what they do, or after. The nand flash memory tends to be overbuilt (some more than others) while the rest of the components vary in quality depending on the market, 'budget' or 'hi end'.
You can throw money at a new ssd if you like - your nvme is practically at least 10x faster than any sata 3 ssd at 3500mb/s on pci-e 3.0 so windows will run fabulous on it. Probably improve your gaming fps a tad too. Spending too much to reduce your overall performance makes little sense.
It does look rather inconvenient to do anything with that much data however so next time you get an nvme migrate the os to it immediately than fill it with data.
So bit of a duff move there, but if you want to run windows on your really fast nvme which is the principle purpose of it you'd have to go back to square one anyway.
Also pretty slow to copy a 2tb nvme to another 2tb hdd since the data transfer is only as fast as the hdd write speed so 2tb must be hours, if you could even make room for the data sounds like you must have a huge game library.
deleting and redownloading 10 50gb games is the same amount of data as 5 100gb games - much of a muchness only delete what you can redownload if you have to, what's the difference between 500gb and 500gb?
That sinking feeling if it turned out not to be the drive? Well your power supply and mobo are also pretty inconvenient and expensive to switch out though the tier B G1 Supernova with 10yr warranty still isn't tier A but it probably isn't transients anyway although the supernova g1 650 review says the transient response is really bad apparently you had a problem before installing a 3090.
The review of the 1000w g1 I found does not mention transient response but says it has good regulation and noise suppression and a 10yr warranty. Tom's did not review the g1 in my search results but did the g2 or 3 and g5.
Well it's kind of not 100% clear but I doubt transients from your 250w titan xp were your original problem only worsened by the 3090ti so that only leaves the crucial drive as the prime suspect. (imo)
The power supply has a ? about what does transient response really mean for power supplies anyway? I don't know enuf jargon. There are two maybes but crucially the crucial is more definitely than maybe while the g1 sounds good but not perfect.
Thanks for the reply.
So a quick update, I downloaded Windows 11, partitioned my NVME and installed a fresh / clean copy to the nvme.
I then went into Windows and installed gpu drivers and pointed to my warhammer directory (forgot to mention, I started playing warhamme the other day and it presents the same problem as bf2042, not heavy RAM, CPU or GPU usage, yet it locks also at random times, sometimes 20 mins, sometimes 40 mins).
I loaded the game and sat it idle for maybe 30 mins, then went into 1 game, and within a short time the PC locked up again, total up time 49 mins.
I have now reset bios to factory defaults, but all that did from the log was change from UEFI to UEFI / Legacy and boot order, so I had to reboot and change them back anyway.
I am about to pull the trigger on a 1250w cooler master as its about the only one that will get here before I go away over xmas.
My last attempts this evening will be, disconnect all HDD’s since the new install is only relying on content in the nvme and retry.
I am also currently running AIDA64 CPU and RAM stress test, 92% memory usage and 100%cpu, more than any game uses when it crashes. I am ruling out GPU seeing as it froze with the titan and the 3090ti, I guess also if it crashes tonight with other hdd’s disconnected then they are ruled out too.
If AIDA runs for a couple of hours, that is longest than the crashes I get running pancake games. Its still so frickin’ weird I’ve been running my GPU flat out in VR with no issues but pancake games using less freeze the damn machine!
So far AIDA is at 31mins, temps are averaging 70 degrees for cpu and mobo is at 34.
If I still get lock ups this eve, then its PSU, Mobo, CPU or RAM. Mobo, cpu and RAM has barely been used though, as I haven’t used my pc all spring and summer / part of autumn. And the lock ups in bf2042 started as soon as I built the machine. Surely with something like OCCT or AIDA stressing cpu and RAM, something would lock up if its an issue? Of course if I DO get a lockup, then it could still be PSU.
I do have a spare 750w evga psu, but I don’t think it wise to connect up, I mean, although gpu and cpu aren’t drawing too much during warhammer, it may not be a good idea?
Thanks.
PS. GPU 53% CPU 56% use and 11GB Ram when it crashed on the clean build. Could it be when the GPU and CPU etc is pulling more power from the PSU it is stable? But during less stress, somehow the power from the PSU is not as stable?
yeah 750w is under-doing it for a 3090ti
So what's the exact part number of the memory - just to check if it's on the support list well you said you got no errors on a mem test and corsairs are quite commonly used but there is a possibility it's off by one or two model numbers seen a case where that caused bsods where the memory would only work with xmp enabled when the memory wasn't strictly qvl compliant which is odd because usually non compliant memory might cause it to glitch out when when xmp is enabled (though I think that's more of a ryzen issue than intel).
Technically the correct procedure for a clean install of windows is to disconnect all the other drives first so the bootloader doesn't end up on the wrong drive - windows setup can do that sometimes.
partitioning the drive should be ok so yes good idea just try it running on one drive although it should work on any drive so the speed differential between the drives isn't an issue I think. Well I have a 980 with my os on it and run fallout 4 from an ssd without any probs.
so maybe power supply but well if you can, try the 'least inconvenient' steps first like switching the memory for something that's known qvl compliant if you have any. Ok so some people say support list compliance doesn't matter much but honestly what documentation do noobs have to go by otherwise? Experienced folks can stick their oars in if they want where are they?
AIDA has been running now for 1hr 30, and warhammer froze within 15 mins earlier…
I added in GPU stress test after 1hr 10, so now its all running pretty much flat out.
After stress test CPU for 1hr 30mins
Min CPU temps, 31,29,30,29
Max CPU temps, 90, 88,92,89
Ave CPU temps, 70,65,73,70
Mobo is at 47, average 36
Voltages after 1hr 30mins
Min
3.3v, 3.328
5v, 5.080
12v, 12.192
Max
3.3v, 3.424
5v, 5.160
12v, 12.384
Ave
3.3v, 3.389
5v, 5.135
12v, 12.278
Memory, 1.20v constant, unchanged.
GPU running 100% power, so far max 71, case sides are on and is about as hot as its going to get in there with RAM, CPU and GPU maxxed.
So far no freeze, time now 1hr 35min
Thanks for sticking with me! :)
CPU-z shows:
CMK16GX4M2D3600C18 which is on the supported list.
Same part no for each stick.
I did get lock ups with both XMP and non XMP profile loaded. I also noticed bios aet timings wrong for XMP profile, so I tried with it manually tweaked, but again still locked up.
I’m going to continue running AIDA to the 2hr mark, that will be way more prolonged CPU, GPU and high memory use than the pancake games that crash. I will then add in HDD for a further hour.
I’ve also ordered a 1250w 80 gold cooler aster PSU (mwe1250 v2), as thats just about the only alright looking one I could get this weekend.
I think the current plan of attack is let AIDA complete at about 3hrs of stress testing, reboot, disconnect the other HDD’s, try war-hammer again.
If it crashes, then maybe I can set vcore to 1.28 manually? Perhaps if there id a PSU issue it is more stable under constant voltage or load?
I guess if it still does it, I’ve ordered the PSU now, so I’ll just replace that and try again.
Failing that, I suppose I’ll then be into sourcing or ordering more memory to see if that helps.
If after all this I still have a problem who knows - haven’t got a clue how to test CPU further or MOBO.
I do keep hoping maybe it could be as simple as tweaking something in the bios, but I am for sure running out of ideas!
Ok well still not Tier A and still no Tom's Review so can't tell you anything about the Cooler Master mwe 1250v2 gold
besides to ensure that you remove ALL the modular cables and don't mix and match them between the power supplies because they are incompatible and will fry so strip out ALL the old power supply cables and don't try to save time by simply removing the psu alone - it all has to go and use ONLY the cables supplied with the MWE. OK?
So all you can do is try it. The bad transient response of the evga g1 is the only other clue I could find so leap to conclusions AFTER you have tested it with the MWE 1250.
What's been there all along is the CPU, MOBO, RAM and Crucial mx200 drive and the evga g1 power supply.
You changed the GPU and the problem persisted.
You (kinda) clean installed on your NVME and took the crucial out of the equation that still leaves CPU, MOBO, RAM and PSU.
Well it ain't a typical CPU crash I don't think. Not an obviously Typical ram crash either.
So still PSU and MOBO. A mobo could have bad capacitors on it that you wouldn't be able to detect. So could a power supply.
Still, groping in the dark a bit but hopefully the picture will become clearer the more you test things.
Thanks. One thing I forgot about is I am using PSU extension cables, white sleeved ones? I haven’t tried with those removed? But I’ve got a new PSU route on way anyway, so plan to plug psu in outside the case, and just directly connect its cable to everything to save a lengthy rebuild before testing. Voltages all look solid at the mo and within tolerance, so??
I’m now at 2hr mark, 1hr full cpu and ram stress test, then added in GPU and at 1hr in with that going 100%, so total time 2hrs (did not stop stress test just added gpu), now adding in ALL local hdds and will continue.
just remove anything that's non standard and try it and whatever you do don't plug a cable from your evga into the cooler master mwe and you should be ok don't personally know anything about psu extension cables never needed to use one but, yes I'd consider extension cables another suspect.
you really want to get the system into a 'barebones' state just the psu and it's cables which shipped with it and belong to it, only one drive, compliant memory, mobo, cpu & cooler, & gpu with the ram seated in the correct normal slots usually a2 and b2 innit?
Then test it before adding anything else. The only way you can find the problem is to 'breadboard' it so to speak and eliminate the suspects by process of elimination.
A couple of other quick observations.
Since I have been unplugging things and poling around inside the PC, I noticed today when I turn the PC PSU on at the back switch it makes a ‘pop’ noise. I am almost certain that this has not happened before and is not normal.
Also, I run an external DAC which I will disconnect tomorrow, when I switched off my speakers that are connected to the DAC, they made a clicking noise and a white flash was seen on my left screen ( was powering down PC and screens just went dark as I turned off the speaker power). So there was some interference from speakers through DAC to thr PC.
Of course could all be coincidental.
Stress test finsihed after 3hrs, no crash. System stable with eveything under heavy use.
Crash seemes to happen when power and use is lower and demand is up and down IE not regular like in stress test.
Not sure of that presents a clue? Sudden spikes or demand / changes in voltage required and this is when it freezes?
Not sure sounds like it's something to do with that 'transient response' but well a power supply that has a 10 year warranty doesn't necessarily mean it won't go wrong. It just means the manufacturer doesn't expect the majority of units to go wrong and they can turn a profit.
Doesn't look like stress testing is giving you much useful info it just crashes with regular usage. merely running a game.
As to who knows what might be wrong with it- better to ask their tech support since they should know more than most. You might be able to get a new one albeit still another tier b with a question mark about it's transient response for another 10 years. So tell 'em, makes a pop noise when you switch off and your pc crashes in normal usage but not in stress tests, they can only give you the runaround or understand the symptoms.
You've a fresh install of windows, installed all your drivers(?), tried a different gpu, and a different drive to host windows, memory is compatible, removed the extension cables, and run lots of stress tests.
Haven't asked if your mobo bios is the most recent but who wants to flash a bios when they aren't sure about a power supply? It's never a good idea to flash a bios in dubious power conditions anyway since the eprom is quite sensitive to errors. Though mainly it's problematical if the power goes out during the flash process.
So choices now, chase the warranty of your EVGA, or try it with the cooler master mwe - dunno if we're gonna get further flogging the horse, what else to do apart from a bios update? You don't have a spare mobo, cpu or mem but they must be ok to withstand so much stress testing, wouldn't you have expected them to go over in 5 minutes if they were faulty?
So just the power supply.
I don't want to speak too soon, but I disconnected all HDDs from PSU and MB and also I disconnected:
Webcam
Scarlet 2i4 DAC
Xbox gamepad dongle
Bluetooth dongle
Have been playing Warhammer for over 3hrs, no lockup...
That doesn't prove I guess its any of those devices and not the PSU, so I suppose I fit the new PSU then reconnect stuff one by one and test.
It could be a fluke though, so I am not reconnecting anything yet until I finish gaming tonight and will also try a session tomorrow AM before swapping PSU when it arrives, then starting to recconect stuff. Fingers crossed!
I'd keep using it until you get another crash, well I suppose it isn't a disaster to have another power supply spare just in case 'tis an expensive business to have spares though especialy since unused items are still using up their warranty time from date of purchase.
However it might make more sense to deduce which of these devices is causing you a headache.
Just saw this after I plugged the drives back in. So after plugging the three drives back in (USB devices still disconnected), I froze within 10 minutes of a game in Warhammer. So I disconnected the two normal HDDs and rebooted. Re-joined the game, and froze again within 10 mins. I then disconnected the old crucial SDD, and reconnected the HDDs, and I managed to finished the game, and I don't want to speak to soon, but still playing. So you may have been right all along! Will keep testing and report back.
Well, unfortunately it locked up again, after 1hr 30. So I went back to all srives unplugged and it locked up at 30 mins.
ARRRRRGH.
This has to be in alp my life building and playing with PC’s the biggest pain in the ass I have ever had.
So back to square 1, I’ll switch the PSU out tomorrow.
