Question PC monitors keep getting "No Signal" randomly
Apr 1, 2019
7
Hey, my pc keeps randomly cutting the signal to my monitors as all three monitors I own get not signal pop up simultaneously and I have no idea why.
It seems to be a recurring issue I have had for over 2 years now, which is a hella long time for such a persistent issue. I have done so much overtime to fix the issue, but I do certain things and it doesn't occur for a while then all of a sudden it pops up again.
I have:
Gone back and fourth installing and removing different software
Completely wiped my pc and started from new.
Bought a new high end PSU thinking my old one was the issue
Gone through so much of my pc's configs its unreal
I just cant seem to find what the problem is, any help would be great ty.
Pc specs
CPU: Intel® Core™i7 Six Core Processor i7-4930K (3.4GHz) 12MB Cache
CPU Cooler: NZXT RL-KRX62-01 280 mm Kraken Series All-in-One Liquid Cooler - Black
GPU: MSI GTX 970 Gaming 4G Twin Frozr
Motherboard: ASUS® P9X79 LE: INTEL® SOCKET LG2011
RAM: 16GB KINGSTON HYPER-X FURY DUAL-DDR3 1600MHz (2 x 8GB)
HDD: 2TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
SSD: Samsung 850 EVO 500 GB 2.5 inch Solid State Drive
PSU: Seasonic Prime Ultra Platinum 750W 80 Plus Platinum Modular Power Supply
Monitor 1: LG 25UM58-P 25-Inch 21:9 UltraWide FHD IPS Monitor - USING HDMI
Monitor 2: Samsung S22F350 22-Inch HDMI LED Monitor - USING DISPLAY PORT TO HDMI
Monitor 3: Some AOC 720p monitor - USING DVI-D TO VGA
Still having the problem if anyone has any ideas
It is really odd as it doesn't happen after a certain activity, time or anything. it just randomly occurs so its hard to say what is causing the problem, the event manager is not doing anything anyway
