Hello,
Need some urgent assistance here!
I have a 1) i7 950
2) Intel Server Motherboard WX58BP
3) Radeon HD 5850 1GB
4) Corsair Dominator 6GB
I have re-applied the thermal paste on my intel stock cooler. I used Coolermaster IC value v1.
http://www.coolermaster.in/product.php?product_id=6689
I used 90% isopropyl alchohol to clean the thermal compound on the CPU as well as the heat sink.
I didnt use much thermal compound on the cpu. A little bit more than the quantity shown in the youtube videos, but I'm not sure that could spread it around to the mobo..
Im doing it for the first time, I was really cautious and did the removing, installing and re-assembling very slowly and the whole process took about 2 hours. Assembled the case and all the connections and the monitor never gave any signal.
Also, one plastic locking screw of the cpu cooler was not perfectly fit. The other 3 went fine, but the last one didnt stick in,tried a lot with pushing, I thought of damaging the cpu due to pressure and left it a bit unfit in the mobo (its still fit in but like 50% of the other screws).
Also,The heat sink fan was a bit more noisy than usual when I turned on the pc..
Can anyone guide me what could be the problem? I am buying a coolermaster hyper 212 evo and just thought to experiment with the heat sink..
I'm so tired ,I really took a lot of time and care in cleaning the cpu,assembling the heat sink and everything..and it took like 3 hours to do all the things perfectly..Just f*cking pissed off after it doesnt boot at all..
Any help could be greatly appreciated!
Thank you!
I have a 1) i7 950
Thank you!
