Question PC not booting, and monitor says "No Signal" ?
Jul 17, 2024
Hello, so my pc is about 3 years old. Everything was working perfectly until 3 days ago. 3 days ago i just 'restarted' my pc and during the boot process it aint booting. System fans are working, gpu is working, but no signal on monitor. I double checked monitor and its fine. So i force shutdown and turned on for like 3 times and it boots up. Everything was fine if i shutdown instead of restart. But today unfortunately i shutdown as normal and when i turned it on after a while, i have this problem. All fans are working, rgb, cpu fans, gpu. But it shows no signal. I double checked on keyboard by pressing capslock and numlock for the light. But its not working. So basically my pc isnt booting but all things are running.
I tried these steps but still the same problem exists:
  • I have only 1 ram stick and i cleaned it.
  • I removed cmos battery and waited 15 mins and put it back in
  • I pressed the power button for some seconds to drain the charge.
I force started my pc several times and it can't boot. I dont know what to do. So i would appreciate if anybody helps, bcuz i can't live without my pc 🤢
My specs :
ryzen 5 1500x
Gtx 1050ti oc edition
8gb ram x 1
Mobo - asus prime a320m-k
Psu - 550W
1tb hhd and 240gb ssd
Things i did to solve :
I did this steps and still the same problem exists.
I force started my pc several times and it cant boot. I dont know what to do. So i would appreciate if anybody helps, bcuz i can't live without my pc ):
My specs :
ryzen 5 1500x
8gb ram x 1
Psu - 550W
Try the steps shown here: https://learn.microsoft.com/en-us/t...rformance/windows-boot-issues-troubleshooting
