Question PC Not Turning On From Power Buttons
autoblogart
359
8
18,695
let's start with my specs Real Quick :
i5 2500k
8gb DDR3 1600mhz
Mobo : Foxconn 2abf
PSU : Advance MPT 5002 (500W)(Non Modular)
the pc was working Okey till yesterday i came to turn on the pc on from power button and nothing happened ( no power at all)
WHAT I HAVE TRIED:
1) I have tried to take the motherboard and everything out of the case
2) Tested PSU with a paper clip and it's running without any issue
3) Took the CMOS battery and everything and tested and still having same issue
WHAT I HAVE NOTICED MAY BE THE PROBLEM
4) I have Unplugged the 24 Pin from the motherboard and kept ONLY the 4pin 12v connected to the motherboard and tried to turn on the psu with a paper clip and then the surprise happened
it turned on ( MOBO only out of pc case, cpu fan spinning and psu , and it didn't shutdown or stopped suddenly until i took the paper clip of the 24 pin)
i have tried to power from the power sw pîns with a metal pen but not working either
what can the problem be ?
Looking Forward for Your Suggestions ,
Thanks
