Greetings!
I hope everyone is fairing well.
When you connect the 4 pin power conector to my motherboard the backside of the CPU gets burning hot fairly quickly and the pc shuts down after that it just goes into a loop. If I remove thét cable, the backside gets slightly warm and the pc runs without t shutting down. By that I guess that it's an overheating issue caused by the 4 pin. Now my issue is, does the problem come from the PSU and needs a swap or does it come from the connector on the motherboard?
My budged is low but affordable so I would like to get it right by either getting a new PSU or a motherboard.
Thank you for the help in advance
Backstory:
Note: even before this I kept getting random blue screens of windows TDR or tdlr? Something along those lines for a few weeks but never causing an issue.
Yesterday I ran into an issue with my pc. It started of with a black screen while playing a game then right after wit a blue screen. The pc restarted just fine but with a catch. All apps kept closing itself if I try t open any windows option window it closes,same with Xbox apps and discord opens but doesn't fully load and stays gray. The only things that worked and stayed open were the browser and the task manager. After trying to fix that with cmd scans and commands I concluded that I need to repair windows or install it new. Problem is,I couldn't get to that,I managed to once get to windows automatic repair tool but I couldn't do anything, M&K weren't powered or detected. After restarting a few times and trying to get my USB tool kit to work,suddenly pc wouldn't boot anymore. It powered on for a few seconds and turned off and so on,sometimes it stops the loop by itself.
That's not the first time this happened, usually due to overheating of accumulated dust, problem is,I cleaned the pc a month ago fully so that can't be it. I decided to check what causes the issues and by trail and error came to the conclusion that If I connect everything but the 4 pin power connector, that the pc would stay un running effortlessly. Idk if it boots up or anything since the 4 pin power es the ports I believe,so I don't get any power on the graphics card mini hdmi outlet perhaps? If I still do then I don't get an image and somehting else has to be wrong too. But for now, 100% confirmed that the 4 pin, when connected, causes CPU overheat as the backside of hit get burning hot in seconds as soon as I connect it. Now,idk if it's an issue by the PSU or motherboard and was hoping that maybe someone could shine a light on the situation before I go buy things by trial an error.
Backstory:
