Question pc wont boot need help
glenntruxel
7
hello, i just got new case fans for my computer, they are corsair ll120 the rgb ones. I installed them all fine booted up computer and then installed corsair ICUE software which lets you customize your fans rgb. but once that software installed my computer wont boot up anymore, ive tried so many things, including trying to boot from a usb to go into safe mode but my pc wont even boot into that. i have it selected in the bios but it doesnt do anything, ive double checked and have the latest windows iso file downloaded. ive taken all my m.2s out and my ssd out to make sure the only ting there was is the usb and still wont boot in it.
PC specs are
cpu 8700k
mobo asus maximus v hero
gtx 1080ti
samsung evo m.2 1tb
samsung 500gb ssd
windows 10 os
I also get a blue screen with the STOP CODE OF machine check exemption.
also everytime i want to restart or turn on my computer i have to shut the psu off and unplug the power supply, other wise it wont turn on or boot. i can get in to the bios fine but that it. windows repair sometimes wants to run after it failing to boot 3 times but it just crashes to a blue screen.
