Hey, so I received my cpu (3600x) from a rma and I've put it in and tried to screw the cooler all went in except 1 I try to put some force and thought it went in so I powered it on and i get a solid red cpu light. No post so I removed the cpu and check if everything was fine and everything looks good. Except the cpu bracket 1 screw hole is worn out .Before the rma it was posting. Now nothing. There was some metal shavings from the screw but I blew it off with compressed air. Could it be the 1 screw that wont go in the causes this please help.
B450 tomahawk max Manuel says the light means no cpu detected or it failed
View: https://imgur.com/a/vVukLoe
