Hi all...I have recently completed a new build, spec as follows :
Dual Tualatin motherboard
2 x Pentium III-S 1400 1.4Ghz Tualatin processors
4gb Crucial Ballistix DDR PC4000 RAM
7950 GT AGP 512mb graphics card (may swap out for Gainward 7800 GS GLH)
160gb Western Digital ATA 100
I would like to add the following :
PCI Wifi adapter
PCI USB 2.0 controller
PCI SATA controller (change the IDE drive for a a sata SSD - for silence and reliability)
What are the best chipsets for the above / recommended products? There are alot of 'Hong Kong specials' going cheap on ebay
Any input welcome...
USB 2.0 (NEC chipset and low profile capacitors)
http://www.ebay.co.uk/itm/5-PORT-USB-2-0-PCI-HUB-CARD-HIGH-SPEED-480MB-NEW-UK-/270841933408?pt=UK_Computing_ComputerComponents_InterfaceCards&hash=item3f0f6fee60#ht_3418wt_1476
USB 2.0 (NEC chipset basic PCB)
http://www.ebay.co.uk/itm/4-1-5-PORT-PCI-USB-2-0-NEC-CHIPSET-HUB-CARD-WINDOWS-7-/200670881123?pt=LH_DefaultDomain_0&hash=item2eb8eaa563#ht_1423wt_881
USB 2.0 (VIA chipset)
http://www.ebay.co.uk/itm/PCI-USB2-0-4-1-port-VIA-6212-chipset-Card-HUB-/230664355958?pt=LH_DefaultDomain_0&hash=item35b4aac076#ht_1669wt_1115
USB 2.0 (VIA chipset ultra)
http://www.ebay.co.uk/itm/NEC-5-PORTS-USB-2-0-ULTRA-SPEED-480MB-S-PCI-CARD-HUB-/290628020008?pt=LH_DefaultDomain_3&hash=item43aac7a728#ht_1537wt_1115
USB SATA
http://www.ebay.co.uk/itm/4-PORT-2-SATA-2-ESATA-IDE-RAID-CONTROLLER-PCI-CARD-UK-/150611139784?pt=UK_Computing_ComputerComponents_InterfaceCards&hash=item23111f9cc8#ht_4884wt_881
USB SATA (Silicon image controller)
http://www.ebay.co.uk/itm/PCI-2-SATA-RAID-Silicon-Image-Sil3112-3112-Card-Adapter-Converter-/330632518665?pt=LH_DefaultDomain_0&hash=item4cfb3bdc09#ht_1885wt_1115
Or there is this card that has SATA and USB 2.0 all in one with a via chipset?
http://www.ebay.co.uk/itm/Gk575-New-SATA-USB-IDE-PCI-PC-Controller-Card-Adapter-VIA-/260863404093?pt=LH_DefaultDomain_0&hash=item3cbcaba83d#ht_2749wt_881
http://www.ebay.co.uk/itm/4-Port-USB-2-0-IDE-eSATA-SATA-Serial-ATA-PCI-Combo-Card-/140609510667?pt=LH_DefaultDomain_0&hash=item20bcfadd0b#ht_2324wt_881
I will happily buy 3 seperate cards - bit unsure about buying 1 card to handle USB and SATA ?
PCI Wifi adapter
USB SATA
