PCIE Power splitters for SLI?
G
Guest
Guest
I have a power supply of (I think) sufficient wattage (750) but it only has two 6pin PCI power connectors for the GPUs. Is there something like a 6 pin power splitter that I could used to have one power connector split and plugged into both power plugs on a graphics card so I can SLI two GTX 275s?
Is there a reason not to do it?
If I do use such a splitter, would it be better to use one power cable per GPU or plug one end of the split into each GPU so both cards?
I will have extra molex connectors. Thanks.
If you can afford 2 275's you can afford a decent power supply.
I have a good 750W power supply that is overkill in my current machine that has a 9800 GTX+ and can not SLI. I was thinking of getting it a new 500W and moving the 750 to a new I7 with one 275 then adding a second 275 later. Reduce the inital cost and spread the expenses out to make it more spouse-palatable. 😉
Thanks, fixed.
