The covering on one of the front panel pins (specifically the ground on the LED pin) is missing.
Sorry for the crappy picture, my phone didn't want to focus on something that small.
Anyway, my question is should I RMA this? Or will this not cause a problem if I just plug it in like normal?
Kind of bumming, I'm building it for my GF and was going to build it while she's asleep tonight...then I discovered this. Luckily I saw it before I unboxed anything else.
It's a fractal Arc MIDI R2 if that makes any difference.
Thank you!
Thank you!
