Question PLEASE HELP, GPU only using x1 PCI line
Feb 12, 2023
I don't know why my 2060 is only using x1 1.1 pci, checked on gpu-z and hwinfo64
Running horribly in games
Already uninstalled drivers with DDU and tried old and new drivers
I have one m.2, and 3 sata drives, never had a problem with PCI lines
Is there a way i can check what lines are they using? how can i give "priority" to the gpu?
It is connected on x16 pci of course
Thank you all for reading and for your help!!🙏
Motherboard and CPU ?
What model motherboard are you using?
What slot did you install graphics card in?
Can you show a photo of your system with side panel removed?
(upload to imgur.com and post link)
Try to run GPU-Z render test - click on "?" next to Bus interface text box.
If with render test running, bus interface value doesn't change, then this can mean either
graphics card installed in x1 slot,​
graphics card damaged,​
cpu socket pins bent/broken.​
