Maybe requires a BIOS update?i have Gigabyte ga H61M S1 rn and rx 560 doesnt work on it.. is there any specific reason to that?
the first link doesnt work, newegg says not found or whateverI've had no issues with generic Chinese motherboards.
https://www.newegg.com/p/1JW-003D-00028?Description=lga 1155 motherboard&cm_re=lga_1155_motherboard--9SIAGSH9HJ0025--Product
^^^Besides this you'd be looking at used boards.
Weird, search for LGA 1155 motherboard at Newegg.the first link doesnt work, newegg says not found or whatever
cant find that exact looking mbWeird, search for LGA 1155 motherboard at Newegg.
Page looks like this.
OML NEWEGG HAS DONE IT AGAIN.What about this one?
https://www.newegg.com/p/1JW-003D-00007?Description=lga 1155 motherboard&cm_re=lga_1155_motherboard--9SIAGSH88V2208--Product
I bought the 1150 socket version for a friend and it worked perfectly.
That may explain why you can't see the items, US here.im from Lithuania btw
can we communicate via Discord? this is very difficult and i cant post photos for some odd reasonWhat about this one?
Maybe just try Googling "1155 socket motherboard generic" and see what comes up?
[/QUOTE
O M G I CANT POST ANYTHING BESIDES TEXT IN HERE.............. NOT EVEN A GYAZO LINK
and i found a top sale best performance Motherboard H61 LGA 1155 socket motherboard DDR3 socket 1155 High quality
thats its name and it supports i7 i5 i3 and ddr3, socket 1155.can this support both rx 560 and i3 3220?
If you post a site that may carry it I could try to help but I'm really unfamiliar with Lithuania sites.but now ill need to find this thing on stores closer to my country since just import fees are like 20 euro
It should work fine.the cpu works, but will it be fine with the rx 560 4gb oc
