I recently upgraded to an rx580 4gb Nitro+ (used) from an HD 4850 and noticed that in a lot of games my FPS will be very low. I have it paired with a new fx8350 overclocked at 4.5GHz (previously an Athlon ii x3 425) and am certain it's not a bottleneck as GPU usage is always 100% and cpu usage is usually low. Also, 8GB of ram and a 550W Enermax Triathlor Power Supply. Motherboard is 990xa-ud3 Rev 3.0 and it's updated to the latest version (excluding a beta version which doesn't seem necessary?)
I've already tried many suggestions, such as a DDU clean installation, older drivers, fresh OS installation, turning off game bar and mode, chill settings but the problem persists.
The game I've tested the most for troubleshooting is Resident Evil 7, and here's what I noticed is happening currently:
When I first get into game, at highest settings and 1080p, FPS is completely fine at 100+, and gpu temps only reach 64 degrees max. However, when I change from SSAO to HBAO+ in the settings whilst still in game, the FPS drops to around 60fps and there's a lot of stuttering. If I then change it back to SSAO, the FPS doesn't change back and stays low permanently until I restart the game. However, sometimes even after a restart I get the same problem. It's so random as to whether performance is normal or not and no matter what I try the problem eventually returns :
Also, MSI Afterburner and Radeon Overlay both show a low power usage by the GPU at the same time as when the FPS is low.
** I also noticed underperforming in Shadow of the Tomb Raider, so it's not just RE7. **
This is my first time posting a forum online for help, so sorry if I forgot to include any information. Hope someone can help, cause I've really ran out of ideas.
