Geforce FX 5500 is getting very old. Looks like it is time for you to upgrade your video card or something...
Anyway, check and see if your monitor could still be turn on or if the electricity still goes to the monitor. If yes, then it probably means that either your video card is broken or the connection wire is bad.
