So recently my pc has been doing this thing where it will black screen, tells me no display, but all LED’s and fans stay on and my case buttons and USB’s no longer work. The only way to turn the pc off is to flip the switch on the psu. I tried replacing ram, it did it without a gpu in it, with a different gpu in it as well. I tried just 1 ram stick, in different slots as well. Sometimes I don’t even get to post. Other times it’s on for 10 minutes and does it. I tried a different PCIE slot as well, still the same result. Would you suspect this is a dying motherboard? My only other guess would be the PSU but the PC stays on so it can’t be that right? My specs are below:
Ryzen 3700x
Msi b550 Gaming Edge WiFi
Corsair h100i cooler
32gb DDR4 Corsair (16x2)
RTX 2070 super
1tb SSD
NZXT h510 case
RM850x power supply
Ryzen 3700x
RTX 2070 super
1tb SSD
NZXT h510 case
RM850x power supply
