Question Potential facelift for wife's system
Phosphonothioic
128
Gave my wife an old build of mine. Looking for opinions on any areas that could use a facelift. She mostly plays WoW and Destiny 2, though is branching out.
Her MB does not have 5.0GHz wi-fi capability, which needs to be addressed. I see where I can get usb adapters for less than $20.
I thought of bumping up the processor to something like a Ryzen 7 2700X, which would need a new board (and I could address wifi/bluetooth then). I already plan on doing a clean install of Win 10 no matter what I do.
Any thoughts of if/how I could spiff the rig up a little? I'm set on the GPU. I can't get to the PSU at the moment, but I"m pretty sure it's a 650W corsair.
Thanks!
PC Partpicker
WildCard999
Herald
This is what I'd recommend, disregard the error message as the motherboard ships with an updated BIOS to support the 3600. The motherboard also has wifi & Bluetooth.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($189.99 @ Best Buy)
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard ($74.99 @ Newegg)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($64.99 @ Newegg)
Total: $329.97
Generated by PCPartPicker 2019-12-12 11:22 EST-0500
Either 3600 or 2700X would work fine, get whatever's cheaper or if she does some editing then the 2700X would be better due to the extra cores/threads. You should be able to reuse that CM EVO 212 as long as you get a AM4 bracket (if you bought that cooler pre-Ryzen).
