Hi,
I just got my new internet form telekom. Its supposedly a 2Gb connection over optical cable and the router i got can transmit it over 2 ports 1000/1000. Since the living room is quit tricky to run wires from the router i got myself a powerline adapter ( zyxel pla5456) that should handle the 2port communication up to 1800mbps and that should be more then enough since the provider willl never actualy handle 2Gbps. The plan was to connect the router directly to the powerline adapter and plug it in the wall, then in the living room also directly in the wall the other one then connect that to a switch over 2 ports and the switch can distribute it to all the hardware that needs it in there. I had two problems. One: the speed i can measure with speedtest drops to ~120mbps over the powerline opposed to ~950 from a direct link with the router. Two: when using the powerline adapter with the switch i get disconnects on random devices while others on the same switch are still connected. Problem one is surely the powerline adapters fault, when i connect the router to the switch the speed stays the same, but problem two can be the switches fault too.
Soo tldr; the questions:
Can it be that the powerline adapter simply looses that much speed due to bad cables in the walls, to much noise? Answered by bill001g. -yes
Can it be that i set something up wrong and the switch doesnt recognize the 2 port connection?
Why do some devices lose connection while others stay connected?
Do i have to change something on the router/powerline adapter/switch to get the dual port communication set up? Answered by bill001g. -powerline is half-duplex
Does setting up a LAG for the two ports going to the router on the switch help at all? Answered by bill001g. -could help not guaranteed due to the algorithm used.
Specs:
router: https://media.telekom.ro/images/docs/Legal_docs/Fix/Specificatie_Tehnica_ONT.pdf
powerline adapter: https://www.zyxel.com/products_serv...Thru-2-Port-Gigabit-Ethernet-Adapter-PLA5456/
switch: https://www.tp-link.com/en/business-networking/easy-smart-switch/tl-sg108e/
Connected devices: 1 PC, 2 laptops, 1 TV
EDIT:
Also, just checked the manufacturers software shows an out/in ~500mbps on the powerline adapter while speedtest measures ~120 on the pc connection where does the rest go?
Thanks,
Chris
Specs:
EDIT:
Thanks,
Chris
