Printing to LPT1 using net use
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax,microsoft.public.windowsxp.general (More info?)
Hi All,
A friend of mine has an old DOS application which can only print to LPT1,
LPT2 or LPT3. He purchased a new PC which only has USB ports. He obtained
a lead which allows windows applications to print to his printer and
after some suggestions from this newsgroup we managed to get the DOS
application printing after sharing the printer as HP1 and using the
following:
net use lpt1: \\127.0.0.1\HP1
This appears to work but there are two problems.
1) You need to re-issue the net use command from a dos box every time
the PC is re-booted. If you type net use it says the LPT1 is unavailable.
I have tried putting a batch file in the start folder for all users but
it does not work. Running the batch program from a dos box works.
2) There is a considerable delay when printing
I do not know if these two issues are related.
Can anyone add any advice on overcomming these issues ?
TIA John
See Bruce Sanderson's article at:
http://members.shaw.ca/bsanders/printfromdos.htm
Cari (MS-MVP Windows Client - Printing, Imaging & Hardware)
www.coribright.com
"The One" <TheOne@nowhere.com> wrote in message
news:Xns951C63C5D9397TheOnenowhere@207.46.248.16...
> Hi All,
> following:
> TIA John
See response inline:
> Hi All,
> following:
Amend your net use command to the following:
net use lpt1: \\127.0.0.1\HP1 /persistent:yes
will make the connection permanent-downside is, if the OS can't
reconnect to the printer at logon, you'll get a bitch box to that effect.
this is a network issue, it is EXTREMELY hard to get delay-free
browsing, etc. these days, what with mixed OS/hardware environment
out there. My suggestion: live with it. The many workarounds
(HOSTS file, etc.) often lead to other problems.
> TIA John
John,
Add /persistent:yes
There could be many reasons for this.
Probably the DOS app. is not closing the printer port at the end of the job,
so XP has to wait for the timeout value before spooling the job.
If this is true, closing the DOS app. will start the job immediately.
You could change the timeout value or (better) fix the DOS app. (if you
can).
If you also have a parallel printer connected to the captured LPT port,
maybe you could consider having Printfil redirecting the job for you.
Redards,
Davide
Printfil - Windows Printing System for Applications
http://www.guolo.com/printfil
Odbc4All - Connection to ODBC Data Sources for any Application
http://www.guolo.com/odbc4all
