I am building a PC from spare parts. But for some reason i keep getting the 00 MSI motherboard code. It has a light next to CPU also. I figured it has something to do with the cpu. I repasted it Still the same error code. When i pulled the CPU plug out and replaced it the PC booted Up. So i am thinking it was just a loose connector. Well I shut down the PC and closed everything back up. Well when i turned it back on i got the same error code again. I thought maybe the power supply is just bad but i changed it still error code. I dont think its the CPU because it did boot up fine that one time. Could it be the motherboard that is just going out?
