G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
Hello, I have a problem I try to set up an "Advanced Conncetion". When I try to set up to "Accept a new connection" in the wizard I get the following error:
Incoming Connections Warning!
"Incoming Connections depend on the Routing and Remote Access service which was unable to start. For more information, check the event log.
In the viewer I get the following message:
The Routing and Remote Access service terminated with service-specific error 499 (0x1F3).
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
When I tag "http://go.microsoft.com/fwlink/events.asp." It gives me this information:
Details
Product: Windows Operating System
Source: Service Control Manager
Version: 5.0
Component: System Event Log
Symbolic Name: EVENT_SERVICE_EXIT_FAILED_SPECIFIC
Message: The %1 service terminated with service-specific error %2.
Explanation
The specified service stopped unexpectedly with the error indicated in the message. Windows does not recognize the service's error code.
User Action
To display the service-specific error code in the Service_Exit_Code field, at the command line, type
sc query service name
The information displayed might help you troubleshoot why the error occurred.
Version: 5.2
Explanation
User Action
I do not know what this means. Ido know in "Services" that when I try to start "Routing and Remote Access" in properties I get this error.
"Windows could not start the Routing and Remote Access on Local Computer. For more information, review the syste. Event Log. If this is a non-microsoft service, contact the service vendor, and refer to service-specific error code 499."
I cannot find a error code 499 on the Microsoft web site.
Can someone help????
Thanks
Details
Version: 5.0
Explanation
User Action
Version: 5.2
Explanation
User Action
Thanks
