Problems with computer.
dece870717
24
6
18,515
My C: drive is raid 0 2 raptors 36GB, and whenever i do reading or writing like loading a game,or copying something over or installing something, there are random freezes where computer will complelty freeze and you cant do anything, so i have to restart the computer.I have my drive D: which is just a IDE 120GB which if doing anythign on there works fine.
Here are full specs AMD Athlon X2 4800+ l ABIT Fatal1ty AN8 SLi l 2 36GB Raptors RAID 0
2GB 4X512MB OCZ Platinum Revision 2 2-2-2-5
2 Evga Geforce 7800GTX KO 256MB SLi l Silverstone SLI 650W PSU
Sound Blaster X-Fi l Logitech Z-2300 2.1 Speakers
Sennheiser HD 280 PRO Headp
First you need to localize what is causing your problems. If your not sure exactly what it is then take out your "D" drive and boot yur computer. If thats not it then take out your raptors and use the IDE, do a temp install of windows on that drive and see if you have the same problem. Im betting there is something in the BIOS that you need to tweak, or mabe its the drivers. My best guess is the incorect BIOS settings and/or driver. If your motherboard is brand new then u might need to wait for a BIOS update or new motherboard drivers. I'v had perfomance probs on my computer too then i updated my motherboard drivers some time later and it was much better.
