Problems with wired pc
gorrow
23
Hello everybody, look here's my problem, the main pc(the one i use for gaming and stuff) which is connected directly to a router, is taking a bit longer to access webpages, load videos, and also is disconnecting me from Battlefield 3. The thing is, if i try accessing the web from a wireless computer, it loads fast. So i wanted to ask you guys, if this is a problem with the pc or router. :ange:
Any advice will be appreciated.
Thanks in advance! 😀
Easy way to test is connecting it directly to your cable/dsl modem. If the connection is still having issues connected directly to the modem then it sounds like a machine problem, if it works fine then most likely a router issue.
