[SOLVED] program to monitor cpu and gpu temps
emieleke
34
hey all,
Does someone know a good and safe program to monitor your pc CPU temp in game?
Ive made a new setup and i want to monitor it for a while.
much thanks!
Intel or AMD?
I always liked HWM, but it sometimes doesn't like to play well with Ryzen/mobo. I started using Core Temp for that. I generally use Afterburner for GPU temps, or just check the task manager/performance tab as many modern GPU report temp to it as well.
Admittedly I have not attempted to locate a program that gives all the same info for the AMD builds as HWM will show for Intel.
Intel or AMD?
Intel or AMD?
Good and safe? Most such programs are safe for practical purposes if you get them from their official site, and do a hash compare.
HWMonitor, GPU-Z, HWiNFO, too many to count.
thanks both for the reply. but found something in the meantime: "speccy" seems pretty good
