Question PSU came without a cable for my GPU
Dec 25, 2021
12
I'm building my first pc right now and while connecting all the cables to my power supply I realise there's no cable compatible with my GPU. There's a connector which fits my gpu but not my power supply and there's a cable that fits my power supply but not the GPU.
My PSU is a fully modular EVGA G3 550watt. My GPU is a 1660 super made by zotac gaming.
I would post pictures of my connectors but I'm not sure how to.
Upload your photos to imgur.com and post links.
Use cable, that has VGA written on it.
One end goes into PSU (8pin end), the other end goes into graphics card (6pin+2pin).
The connector doesn't fit with my GPU. The connector plugs into my PSU perfectly fine then I go to plug it into my GPU the shapes didn't match up and I can't plug it in.
The 6+2 connector is intended to go on one way. The locking clip on it mates with the retention portion of the socket on the GPU. The connector on the GPU is a standard pin-out.
You don't have the connector flipped over, or the +2 part jammed onto the wrong side of the 6 side do you?
