Question PSU Whine Coil/Fan Bearing Noise
Dec 15, 2021
So recently I've noticed that some noise been coming off my PSU (Thermaltake Smart Series 80Plus White) with 13 Months of usage.The noise sounds like a coil whine but could also be the Fan bearing although the noise goes off when the computer goes into high load (Ex: Playing a game) and only starts when I'm mostly idle or browsing the internet.I believe if its coil whine it shouldn't be a problem right?I'm trying to diagnosis the cause but that's what I have off so far.
Audio:https://drive.google.com/file/d/1GUVLZD_2qL_qxKzwy8ygM0LRA3qi8WWy/view?usp=sharing
The link is a private one.
In any case, this is a very low quality PSU, so if you're using a dedicated GPU, the PSU ought to be replaced anyway.
The GPU is even older than the PSU, I just wanna know if this won't bring me any problems in the future as I don't have any means to replace it right now,and if I do I'll probably get a new rig considering my parts are pretty outdated.
PS:The link should be public now
