Hello, iam looking different type of monitors to buy this week and i have some questions. I'm between some options, and i looked some reviews and forum threads about people who have it.
First of all, i want the monitor to play FPS and code. So the miniums i am search it are 144hz 1ms and adjustable base.
AOC 24G1 is one of the first options, i search some information and thoughts about and the only reason i am not really sure about get this monitor is because is VA Panel and some people experiment headaches because texts are little bit blurry and i want it to play and code (so i need good text definition). I look at this on reddit.
AOC 24G1
Benq GL2450 (random monitor)
Another option i have is Millenium MD25PRO , i see this panel is TN and i don't have any problem about it (iam not to exquisit about colors but i am kinda worry if there is a big color difference between VA and TN panels). I didn't find any review about so i can't give more information.
My specs are:
Ryzen 5 2600
AMD RX 580
16 GB RAM
If you have any good recomendation between 200-230€ comment it below. If you can help i really appreciate it, if you need more info make me know it.
Thank you all
AOC 24G1
My specs are:
Ryzen 5 2600
AMD RX 580
16 GB RAM
Thank you all
