Dear users,
i have a question regarding RAM capability with cpu and mobo
CPU, Xeon 1620 v3
Memory Types DDR4 1333/1600/1866/2133
Mobo, Asus x99 pro
and where I'm from, i found RAM with 2133 and 3200 with the same prace.
i understand that RAM speed will probably be downclocked to match the lowest FSB/Memory controller in the system, in my case the CPU, therefore there going to be no difference in performance between those two speeds.
question, is this combo: my CPU and Mobo with Ram at 3200 will work normally and stable, or it will be better to go with 2133 ? what is your point of view in this matter, and what is best CPU for this build.
and please, where i can find RGB liquid cooler for LGA 2011v3 Socket ? site must support shipping to Tunisia.
CPU, Xeon 1620 v3
Mobo, Asus x99 pro
Memory | 8 x DIMM, Max. 64 GB, DDR4 3300 (O.C.) / 3200 (O.C.) / 3000 (O.C.) / 2800 (O.C.) / 2666 (O.C.) / 2400 (O.C.) / 2133 MHz Non-ECC, Un-buffered Memory Quad Channel Memory Architecture Supports Intel Extreme Memory Profile (XMP) |
