Question Random audio drop out from Notebook's Loudspeakers
Nov 20, 2018
5
Hello Forum, hope some expert can give me a heads up on a audio issue I've never been trough.
I'm an audio enthusiat and have worked on PC desktop recording independient band a music projects.
Recently bought an used laptot since im traveling ( nothing high end, as everything is super expensive in south america)
What happens is basically random audio drop-out from the notebook's incorporated soundspeaker. But still sending audio signal into line audio output.
  • Nothing plugged into the computer
  • Audio drivers still enable, no error sign poping up
  • No error in device manager
  • Audio Drivers are correctly installed (From the thosiba support site: https://support.toshiba.com/support/modelHome?freeText=3361153&osId=31 )
  • Also using Assio4All when using any DAW
  • Playing or not any kind of audio source, nothing plugged into the computer, randomomly audio goes out while sound coming from the soundspeakers. Not making any difference if sound coming from the spekares is high or low (SPL)
  • If the notebook goes to sleep or hibernate or reboot, when wake up, sound comes back into the loudspeakers (for a little while, then goes out again)
  • I've tried using 2 SSD i have with different Windows 7 copies I have and have the same problem with both.
  • Could that be a bios problem? Since I've updated it from the original one
Below I leave system information. Hope someone could help! Since is not a critical problems, it is really inconvenient.
Computer: Toshiba Satellite L745-SP4201A
System Information
Time of this report: 4/25/2019, 10:55:24
Machine name: JULI-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_ldr.170913-0600)
Language: Spanish (Regional Setting: Spanish)
System Manufacturer: TOSHIBA
System Model: TE5
BIOS: InsydeH2O Version 03.60.452.60
Processor: Intel(R) Core(TM) i3-2350M CPU @ 2.30GHz (4 CPUs), ~2.3GHz
Memory: 8192MB RAM
Available OS Memory: 8140MB RAM
Page File: 6566MB used, 9711MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics Family
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_FCD01179&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Monitor PnP genérico
Monitor Model: unknown
Monitor Id: LGD02F8
Native Mode: 1366 x 768(p) (59.996Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumdx32,igd10umd32,igd10umd32
Driver File Version: 8.15.0010.2353 (English)
Driver Version: 8.15.10.2353
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 4/4/2011 21:09:00, 7473664 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-4256-11CF-F87B-DADCA9C2C535}
Vendor ID: 0x8086
Device ID: 0x0116
SubSys ID: 0xFCD01179
Revision ID: 0x0009
Driver Strong Name: oem2.inf:Intel.Mfg.NTamd64:iSNBM0_Q0:8.15.10.2353😛ci\ven_8086&dev_0116&subsys_fcd01179
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Altavoces (Dispositivo de High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_14F1&DEV_5069&SUBSYS_1179FCD0&REV_1003
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7601.17514 (Spanish)
WHQL Logo'd: n/a
Date and Size: 11/21/2010 01:23:47, 350208 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Teclado
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: 2.4G wireless USB Device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x279E, 0x024E
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ Concentrador raíz USB
| Vendor/Product ID: 0x8086, 0x1C26
| Matching Device ID: usb\root_hub20
| Service: usbhub
| Driver: usbhub.sys, 10/27/2017 19:24:11, 343552 bytes
| Driver: usbd.sys, 10/27/2017 19:24:11, 7808 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ Teclado PS/2 estándar
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/13/2009 21:19:57, 105472 bytes
| Driver: kbdclass.sys, 7/13/2009 23:48:04, 50768 bytes
+ Dispositivo de teclado HID
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 11/21/2010 01:23:47, 33280 bytes
+ Controlador de teclado de Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Synaptics PS/2 Port TouchPad
| Matching Device ID: *tos0220
| Upper Filters: SynTP
| Service: i8042prt
+ Mouse compatible con HID
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/13/2009 22:00:20, 31232 bytes
| Driver: mouclass.sys, 7/13/2009 23:48:27, 49216 bytes
+ Controlador de mouse de Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/21/2010 01:23:47, 63360 bytes
| Driver: sermouse.sys, 7/13/2009 22:00:20, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 149.7 GB
Total Space: 238.0 GB
File System: NTFS
Model: Samsung SSD 750 EVO 250GB ATA Device
Drive: D:
Model: TSSTcorp CDDVDW SN-208AB ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (Spanish), 11/21/2010 01:23:47, 147456 bytes
System Devices
Name: Puente PCI estándar de PCI a PCI
Device ID: PCI\VEN_8086&DEV_1C1A&SUBSYS_FCD01179&REV_B4\3&11583659&0&E5
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (Spanish), 11/21/2010 01:23:47, 184704 bytes
Name: Puente PCI ISA estándar
Device ID: PCI\VEN_8086&DEV_1C49&SUBSYS_FCD01179&REV_04\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 23:48:27, 15424 bytes
Device ID: PCI\VEN_8086&DEV_1C10&SUBSYS_FCD01179&REV_B4\3&11583659&0&E0
Name: Controladora simple de comunicaciones PCI
Device ID: PCI\VEN_8086&DEV_1C3A&SUBSYS_FCD01179&REV_04\3&11583659&0&B0
Driver: n/a
Name: Controladora estándar PCI IDE de doble canal
Device ID: PCI\VEN_8086&DEV_1C09&SUBSYS_FCD01179&REV_04\3&11583659&0&FD
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 23:45:45, 12352 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (Spanish), 7/13/2009 23:45:46, 48720 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 23:52:21, 24128 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.18231 (Spanish), 10/27/2017 19:11:39, 155584 bytes
Name: Controlador de host de PCI a USB mejorado
Device ID: PCI\VEN_8086&DEV_1C2D&SUBSYS_FCD01179&REV_04\3&11583659&0&D0
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.23529 (Spanish), 10/27/2017 19:24:11, 56320 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.23529 (Spanish), 10/27/2017 19:24:11, 327168 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.23529 (Spanish), 10/27/2017 19:24:11, 343552 bytes
Device ID: PCI\VEN_8086&DEV_1C01&SUBSYS_FCD01179&REV_04\3&11583659&0&FA
Device ID: PCI\VEN_8086&DEV_1C26&SUBSYS_FCD01179&REV_04\3&11583659&0&E8
Name: Intel(R) HD Graphics Family
Device ID: PCI\VEN_8086&DEV_0116&SUBSYS_FCD01179&REV_09\3&11583659&0&10
Driver: n/a
Name: Controladora de bus SM
Device ID: PCI\VEN_8086&DEV_1C22&SUBSYS_FCD01179&REV_04\3&11583659&0&FB
Driver: n/a
Name: Puente PCI de CPU host estándar
Device ID: PCI\VEN_8086&DEV_0104&SUBSYS_FCD01179&REV_09\3&11583659&0&00
Driver: n/a
Name: Controladora de High Definition Audio
Device ID: PCI\VEN_8086&DEV_1C20&SUBSYS_FCD01179&REV_04\3&11583659&0&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (Spanish), 11/21/2010 01:23:47, 122368 bytes
Name: Atheros AR8152/8158 PCI-E Fast Ethernet Controller (NDIS 6.20)
Device ID: PCI\VEN_1969&DEV_2062&SUBSYS_FCD01179&REV_C1\4&13FB76A6&0&00E6
Driver: n/a
Device ID: PCI\VEN_8086&DEV_1C1C&SUBSYS_FCD01179&REV_B4\3&11583659&0&E6
Name: Atheros AR9002WB-1NG Wireless Network Adapter
Device ID: PCI\VEN_168C&DEV_002B&SUBSYS_661311AD&REV_01\4&4641646&0&00E5
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.19091
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.19091
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.19091
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7601.19091
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7601.19091
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.19091
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.19091
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7601.19091
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7601.19091
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.23709
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.19091
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.23709
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.23709
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.17037
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.23709
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.23709
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.23709
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.19091
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.23709
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.23709
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.23709
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.19091
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.23709
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.23709
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.23709
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.23709
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.19091
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.23471
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,,
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.19091
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.19091
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.19091
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.23709
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.23709
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.23709
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.23709
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.23709
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.23709
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7601.23285
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.23709
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.23709
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.23709
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.23471
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.23709
WDM Streaming Tee/Splitter Devices:
Convertidor de derivador/consumidor a consumidor,0x00200000,1,1,ksproxy.ax,6.01.7601.19091
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7601.19091
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7601.19091
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7601.19091
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.23709
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7601.19091
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7601.19091
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.23709
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.23709
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.23709
Ley A CCITT,0x00200000,1,1,quartz.dll,6.06.7601.23709
Ley u de CCITT,0x00200000,1,1,quartz.dll,6.06.7601.23709
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.23709
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.19135
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.19135
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.19135
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.23709
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.23709
WDM Streaming Capture Devices:
Micrófono 2 de HD Audio,0x00200000,1,1,ksproxy.ax,6.01.7601.19091
Chicony USB 2.0 Camera,0x00200000,1,2,ksproxy.ax,6.01.7601.19091
WDM Streaming Rendering Devices:
Altavoz de HD Audio,0x00200000,1,1,ksproxy.ax,6.01.7601.19091
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.19135
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.19135
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.19135
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.19135
WDM Streaming Communication Transforms:
Audio Renderers:
Altavoces (Dispositivo de High ,0x00200000,1,0,quartz.dll,6.06.7601.23709
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.23709
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.23709
DirectSound: Altavoces (Dispositivo de High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.23709
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Hi, thankz for the reply.
Im not really sure if it was a clean Installation, must I believe so. But loudspeakers were working fine on both SSD.
I've installed the latest version of the H20 Insyde available on the toshiba site
(the same site I got the audio drivers files) Could that be? I'm attaching DxDiag with BIOS info
Thankz in advance
System Information
Time of this report: 8/18/2019, 21:10:24
System Model: TE5
Memory: 8192MB RAM
Page File: 5022MB used, 11892MB available
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 2: No problems found.
Sound Tab 2: No problems found.
Display Devices
DAC type: Internal
Monitor Id: LGD02F8
DDI Version: 10.1
Driver Date/Size: 4/4/2011 20:09:00, 7473664 bytes
WHQL Logo'd: n/a
Vendor ID: 0x8086
Device ID: 0x0116
Revision ID: 0x0009
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
DAC type: Internal
Current Mode: 1920 x 1080 (32 bit) (59Hz)
Monitor Model: T22C310
Monitor Id: SAM0AE9
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
DDI Version: 10.1
WHQL Logo'd: n/a
Vendor ID: 0x8086
Device ID: 0x0116
Revision ID: 0x0009
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: T22C310 (Sonido Intel(R) para pantallas)
Hardware ID: HDAUDIO\FUNC_01&VEN_8086&DEV_2805&SUBSYS_1179FCD0&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: IntcDAud.sys
Driver Version: 6.14.0000.3074 (English)
WHQL Logo'd: n/a
Date and Size: 10/15/2010 01:28:16, 317440 bytes
Other Files:
Driver Provider: Intel(R) Corporation
Cap Flags: 0x0
HW Memory: 0
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: n/a
Date and Size: 11/21/2010 00:23:47, 350208 bytes
Other Files:
Cap Flags: 0x0
HW Memory: 0
Description: Micrófono (Dispositivo de High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
USB Devices
| Service: usbhub
+-+ Generic USB Hub
| | Service: usbhub
Gameport Devices
PS/2 Devices
| Service: i8042prt
| Service: TermDD
| Service: i8042prt
| Service: TermDD
Drive: C:
Free Space: 26.0 GB
File System: NTFS
Drive: D:
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (Spanish), , 0 bytes
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
DirectShow Filters
DirectShow Filters:
AAudioRipper,0x00200000,0,0,AudioRipper.ax,
Digiclock,0x00200000,0,0,DigiRefClock.dll,10.03.0000.0028
SyncReader,0x00200000,0,0,DigiSyncReader.dll,10.03.0000.0028
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.23471
PGTimeStamp,0x00200000,1,1,PGTimeFilter.dll,2.00.0000.0010
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.23471
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.23709
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.23471
Video Compressors:
Códec Cinepak por Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Códec Intel IYUV,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
Audio Capture Sources:
Micrófono (Dispositivo de High ,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
Midi Renderers:
Salida de sonido Intel(R) para pantallas 1,0x00200000,1,1,ksproxy.ax,6.01.7601.19091
BDA CP/CA Filters:
Audio Renderers:
T22C310 (Sonido Intel(R) para p,0x00200000,1,0,quartz.dll,6.06.7601.23709
DirectSound: T22C310 (Sonido Intel(R) para pantallas),0x00200000,1,0,quartz.dll,6.06.7601.23709
Quality Flags: 2576
Enabled:
Force throttling
Allow scaling
Enabled:
Force throttling
Allow batching
Force scaling
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
