Question random power loss, could supply be failing?
foxfries
29
hey there,
some time ago my pc started doing this thing where it randomly shuts off and immediately turns back on afterwards. my friend that rewired my stuff a bit ago said that the cable connecting the power supply to the motherboard was a bit strained so i tried unplugging and replugging it after which the random shutdowns stopped for about 2 months but now it just happened again. could it be the same problem, should i get a new power supply or is there any way to test if the power supply is actually failing?
regards
edit: i rewired the power cable so that there's no strain on it anymore, time will tell whether that helped or not. any other suggestions are still welcome though!
full system spec? include make and model of the psu
hey, thanks for the reply. rewiring the cable didn't do anything, my pc just randomly turned off again. my specs are as follows:
Cpu: Intel Core i7-6700k 4GHz
Motherboard: Asus E3 Pro Gaming V5
GPU: Asus Nvidia Gtx 1060 Dual 6GB
RAM: Kingston Hyper X Fury DDR4 RAM 2133 MHz 2x8GB
Soundcard: Creative Soundblaster Fatality
Power: BeQuiet! Straightpower 500W BQT E7
1 SSD 100GB with Windows 10 installed
2 HDD 500GB
1 HDD 3TB
