G
Guest
Guest
Just upgraded to AMD Athlon XP 2000, Geforce4 ti 4600, Windows XP and using my year and a half old Soundblaster Live Platnium 5.1 w/ digital output.
The drivers I had did not work w/ Windows XP so the guy that did the upgrade for me had an extra SB Live CD with XP drivers on it that he used.
Now the funny part: My front speakers work fine. The rear speakers work when I hit the test button (in speaker config. in AudoHQ) they do not work in games or when I play the sounds in Control pannel. They DO work w/ MultiMedia Player.
I have made sure I'm set to 4speaker config. in Control Pannel>Sounds>Advanced>Speakers and in AudioHQ>Speakers. Also for some reason I'm unable to bring up Multimedia (I think that what it was called) in AudoHQ.
I'm using 4 satilite speakers w/ subwoofer, Boston Accutics (sp?)Brand about a year and half old.
If anyone has any ideas on anything I can try or change I'm open to suggestions.
Thanks a bunch.
Thanks a bunch.
