I just bought an old(er) openMesh 24 port POE switch, and decided to replace it's fans. The existing fans were some 12 V, 3 pin fans from Sunon.
As a replacement I bought two NF-A4x20 PWN from Noctua. Those are 12 V 4 pin fans
When the switch starts (using the original fans) they spin up to maximum speed, and then settle at a lower speed, which I measured to 7V.
However, when I replaced the stock fans with my Nocuta fans they don't spin, and the switch runs with a "fault" LED blinking. I assume this is because the fans doesn't spin and the signal wire therefore is 0V. However, I'm a little puzzled by the fact that it also doesn't spin up during the initial booting phase where the stock fans normally spin at 100%.
If I keep the stock fans in, and just yank the voltage and ground wires from the nocuta fans down in the same connector as the stock fan it behaves like I would expect. Which is that it spins during the booting phase, and then stops when the voltage drops.
I have currently just installed the noctua fans, and accepts that I have a "fault" led blinking as well as the fans doesn't spin. I hope that they will start spinning if needed, and the switch supplies them with full 12V power instead of the current 7V.
Now, my questions are:
- Is it true that the fans shouldn't be able to spin at all at 7V Should I buy a 5V fan instead?
- Is this a safe setup? I should note that the switch is rated for over 400W and I expect to draw perhaps 15W from it.
