I don't know what else to do...hope you guys can help me so I have this PC that was making a loud noise with the fan so I thought it might have dust on it so I decided it would be a good idea to replace the thermal paste and clean the fan a little, so I did that, cleaned the heatsink, the heatsink is the regular intel heatsink reapplied thermal paste cleaned the cpu while doing that and done, now I log in to windows 10 and I find that there's no audio. I immediately go to the bios settings to see if I messed up something but it seems like the onboard audio is enabled.
Specs:
MB: GIGABYTE H81M-H
MEMORY: 8GB DDR3
CPU: INTEL CORE I3 4170
I own no graphics card I use this computer normally for work im okay with intel graphics
I already updated the BIOS, formatted a clean install of windows 10 , this motherboard uses realtek audio so I reinstalled the drivers for that, been uninstalling and reinstalling drivers for the past day and honestly I don't know what else to do I'm not sure what I did wrong the PC works normally the only thing missing is the audio.
Note when I connect the headphones it detects the headphones and when seeing audio devices it shows that it's playing even though I can't hear anything, my headphones are fine I tested them somewhere else and even tested with another pair of headphones.
Specs:
MB: GIGABYTE H81M-H
MEMORY: 8GB DDR3
