Replacement for heat sink SNK-0040 - 1U Passive Copper Heatsink with Mounting Sc
ak1982
6
Hi
Could someone please help me find a suitable replacement for "SNK-0040 - 1U Passive Copper Heatsink with Mounting Screws" for a used supermicro 6013P-T server I bought recently. Else kindly tell where can I buy this heat sink in UK.
Regards
AK
hairystuff
This might be usefull, although you might have to remove the fan for it to fit:
http://www.scan.co.uk/Products/Akasa-AK-380-2U-Heat-Sink-Fan-for-Intel-Xeon-Nocona-%28Intel-604-pin%29-Twin-Ball-Bearing-Fan
If your 1U has ducting (like the Dell PowerEgde 1850) for cooling then removing the fan shouldn't cause a problem and this heatsink should fit fine.
If the screw gaping is the same as the LGA771 as on the SKT604 then look into these heatsinks instead:
Aluminum:
http://www.scan.co.uk/Products/Akasa-Aluminum-AK-388-1U-cooler-for-Intel-LGA-771-%28-Demsey-%29-screws-fitting
Copper:
http://www.scan.co.uk/Products/Akasa-All-copper-AK-383-1U-passive-heatsink-for-Intel-LGA-771-%28-Demsey-%29-screws-fitting
ak1982
6
:D Thanks a lot hairystuff!!!
ak1982
6
Bought a "Akasa AK-380-2 Intel Xeon Nocona Copper Cooler 604 pin". got rid of the fan and the heatsink fits perfectly. Thanks again hairystuff
