[SOLVED] Replacement Motherboard//HELP//
brandonthejackbo
I had a Z390 Phantom Gaming 4-CB that I recently poured water on when I got a little too thirsty.
Apparently those aren't produced anymore so I'm looking for a replacement.
Any suggestions? I don't mind downgrading in terms of ram slots from 4 to 3. However I'm fine spending around 300 dollars or so, and everything else has to be compatible.
Sorry if I make any mistakes I'm somewhat inexperienced, particularly with boards.
Thanks for taking the time to look this over.
Here are the specs.
http://www.ascendtech.us/asrock-z390-phantom-gaming-4-cb-no-i-o_i_mbdskz390pgm4cb.aspx
or
ASRock Z390 Phantom Gaming 4-CB Intel Chipset Z390 Socket LGA1151 DDR4 HDMI D-Sub DVI-D USB SATA 6Gb/s ATX Desktop Motherboard 80-MXB960-A1A01.
Chipset: Intel Z390
Socket: Intel LGA1151
Compatible/Supported CPU: 9th and 8th Gen Intel Core Processors
Max Supported Memory: 128GB
Number of Memory Slots: 4
Memory Type: DDR4 SDRAM
Storage Interface: SATA 6Gb/s
RAID Support: RAID 0, RAID 1, RAID 5 and RAID 10
Wireless Lan Support: Gigabit LAN 10/100/1000 Mb/s
Audio: Realtek ALC892 Audio Codec
Connectors: 1x COM Port Header; 1x TPM Header; 1x Power LED and Speaker Header; 2x RGB LED Headers; 1x Addressable LED Header; 1x CPU Fan Connector (4-pin); 3x Chassis/Water Pump Fan Connectors (4-pin) (Smart Fan Speed Control); 1x 24 pin ATX Power Connector; 1x 8 pin 12V Power Connector; 1x Front Panel Audio Connector; 1x Thunderbolt AIC Connector (5-pin); 2x USB 2.0 Headers (Support 3 USB 2.0 ports) (Supports ESD Protection); 2x USB 3.1 Gen1 Headers (Support 4 USB 3.1 Gen1 ports) (Supports ESD Protection); 1x Performance Mode / Easy OC Header.
Input/Output Ports: 1x Antenna Ports; 1x PS/2 Mouse/Keyboard Port; 1x D-Sub Port; 1x DVI-D Port; 1x HDMI Port; 2x USB 2.0 Ports (Supports ESD Protection); 1x USB 3.1 Gen2 Type-A Port (10 Gb/s) (Supports ESD Protection); 1x USB 3.1 Gen2 Type-C Port (10 Gb/s) (Supports ESD Protection); 2x USB 3.1 Gen1 Ports (Supports ESD Protection); 1x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED); HD Audio Jacks: Line in / Front Speaker / Microphone.
Expansion Slots: 2x PCI Express 3.0 x16 Slots (PCIE2/PCIE4: single at x16 (PCIE2); dual at x16 (PCIE2) / x4 (PCIE4)); 3x PCI Express 3.0 x1 Slots (Flexible PCIe); Supports AMD Quad CrossFireX and CrossFireX; 1x M.2 Socket (Key E), supports type 2230 WiFi/BT PCIe WiFi module and Intel CNVi (Integrated WiFi/BT).
Form Factor: ATX
Type: Desktop Motherboard
Supported Operating System: Microsoft Windows 10 64-bit
Features: Supports HDMI 1.4 with max. resolution up to 4K x 2K (4096x2160) 30Hz; 10 Power Phase Design; Supports DDR4 4300MHz+ (OC); 2 PCIe 3.0 x16, 3 PCIe 3.0 x1, 1 M.2 Key E for WiFi; AMD Quad CrossFireX and CrossFireX; Graphics Output Options: HDMI, DVI-D, D-Sub; 7.1 CH HD Audio (Realtek ALC892 Audio Codec), ELNA Audio Caps; 6 SATA3, 2 Ultra M.2 (PCIe Gen3 x4 & SATA3); 2 USB 3.1 Gen2 (Rear Type-A+C), 6 USB 3.1 Gen1 (4 Front, 2 Rear); Intel Gigabit LAN; ASRock Polychrome SYNC
Reactions: brandonthejackbo
Reactions: Aeacus
