S SlimeyDome Feb 25, 2019 2 0 10 Feb 25, 2019 #1 So I found this AIO CPU cooler - Cooler Master MasterLiquid ML240L RGB and it got me thinking. Can I "chain/connect" the rgb cable (4-pin) to my rgb led strips (4-pin) if they are both supported in the softwave (Gigabyte's RGB fusion)?
Solution rubix_1011 Feb 25, 2019 Yes, provided they follow the same Ground+R+G+B 4-pin setup. Is it this one? https://www.tomshardware.com/reviews/cooler-master-master-liquid-ml240l-rgb,5345.html If so, I did the review on it, it's an alright cooler and I believe it is normal 4-pin RGB compatible.
rubix_1011 Contributing Writer Moderator Jan 12, 2007 16,689 658 60,190 Feb 25, 2019 Solution #2 Yes, provided they follow the same Ground+R+G+B 4-pin setup. Is it this one? https://www.tomshardware.com/reviews/cooler-master-master-liquid-ml240l-rgb,5345.html If so, I did the review on it, it's an alright cooler and I believe it is normal 4-pin RGB compatible. Upvote 1 Downvote Solution
S SlimeyDome Feb 25, 2019 2 0 10 Feb 25, 2019 #3 Yes, it is. Thank you for the help and reply. 😊 Upvote 0 Downvote
