I've been thinking about upgrading my case for more cooling since I have 3 fans and I have room for up to 5 fans. Right now the fans is connected to the fan hub which is connected to the PSU. My Asus motherboard is "Aura sync" compatible and has two RGB headers and they are 4 pins. The problem is, the aura fans that I'm looking at has 3 pins. I am not sure if the "fan hub" that connects to the motherboard "PWM FAN Header" is compatible with my motherboard.
This is my motherboard and the RGB Fan Headers are highlighted in yellow.
Here is the fan that I want for my case.
And here is where I am unsure if this compatible to the 4 pins on my motherboard.
Will using an adapter like this one should be able to do the trick to support 3 pins to 4 pin and be able to control the speed and change my RGB colors using the software instead of reaching into the case to the hub just to either change the color or speed.
https://www.amazon.com/dp/B07F8LV1B...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
