I am not an expert in these things so I probaly wont be able to do that. But I just wonder how it should need replacing so fast when the card is less than a week old.. Also I've noticed a "weird" smell coming from my pc after getting the card, read about it online and people are saying its normal for a new GPU to do a little mech smell, is this correct? And also thank you for the quick response!Critical temps for rtx cards are 95C. Try changing thermal compound(thermal paste)It might help.
Also I can make the card go to a max of 86 if I move the max temp in afterburner to 83, still 3 over target but I can keep it cool that way I guessI am not an expert in these things so I probaly wont be able to do that. But I just wonder how it should need replacing so fast when the card is less than a week old.. Also I've noticed a "weird" smell coming from my pc after getting the card, read about it online and people are saying its normal for a new GPU to do a little mech smell, is this correct? And also thank you for the quick response!
Hi thanks for replying. The thing is I find it hard to believe that it's my case. I have 3 front fans and one AIO at the back still shooting air into the case. When i put my max temp on my GPU through afterburner to 81, the card reaches a max of 86, I spoke to nvidia yesterday and they say this is completely normal for the RTX series. Although I would still love to hear your meaning in this!do you have poor case ventilation and? more often than not its the poor airflow and not the card causing high temps
Hey! Sorry for not replying, the amount of thermalpaste might be very pour from the factory or it didn’t spread as it was meant to. you can check a lot of videos on youtube how to change it. Believe me it is not that hard as you may think.I am not an expert in these things so I probaly wont be able to do that. But I just wonder how it should need replacing so fast when the card is less than a week old.. Also I've noticed a "weird" smell coming from my pc after getting the card, read about it online and people are saying its normal for a new GPU to do a little mech smell, is this correct? And also thank you for the quick response!
