Hello!
I just did a fresh re-install of Windows 10 and drivers. Before that, i cleaned the PC with compressed air.
My PC has been running without issues and the main game i play, the GPU temp would sit at 60 degrees C.
NOW. I installed all my drivers and games. I started the game and when i went into a battle, it immediately made a very weird metal grinding noise and the GPU would get very hot...The temp just kept going up and i closed the game after a few seconds when it got over 75 degrees C....
I am pretty sure it comes from the GPU. It is NOT the fans. I can control the fans and i tried to put them at 100%, they sound normal.
Whenever i run a GPU stress test, it immediately makes that strange noise. What did i do?!
What does this sound like? Here is a video of the sound. Might have to turn your volume up, i find it hard to hear with my speakers. -
View: https://vimeo.com/760728254
Thank you!
Thank you!
