I got an ASUS RTX 3060 TI KO OC and went to adjust the control of the fans in MSI Afterburner as I always do, but basically the fans do not stay on below 45% speed whenever I put below that value they turn on and off quickly. If someone could tell me if this is normal or if there is a way to make the fans work below 45% of speed.
Note: During the games the fans turn on and stay on whenever they pass 55 degrees. and her temperature is very cold about 65 degrees at most.
Note2: Even when I turn off the automatic mode continues with the same problem
