Question rx 580 8gb crashing after strees test or after running a game for 3 mins
I have a
-580 8gb msi
-ryzen 5 3600
-16 gb corsair 3200mhz ram
-asrock 450 motherboard
-mars gaming 550W psu
-500gb teamgroup ssd
i used to play with no crashes then my screen crashed (no display)
then i had to activate the gpu and reinstall drivers...
it started crashing every 40/50 mins
then every 10 mins
then every time i run a game
fn or gta doesnt even open...
amd strees test crashes after 5 seconds
What i tried?
-Reinstalling windows
-Uninstalling drivers with ddu
and installing previous drivers
-clocking gpu at 1200mhz and 1366 mhz
-changing thermal paste
ANY HELP?
You are using a cheap quality PSU model, which isn't a very reputable and/or a trusted power supply brand to begin with. So this could most likely be the culprit here, since Mars Gaming PSUs are not recommending to power gaming PCs usually rocking a discrete powerful GPU, or otherwise.
Don't skimp on the PSU, since this is the most important PC component. My suggestion would be to change and upgrade your current PSU model with a HIGH quality reliable unit, for your current gaming rig.
But in any case, you should consider changing your current PSU model for safety reasons. Get a reputed high TIER PSU brand and model.
that might fix the problem?
ill try
From a technical and practical perspective replacing your current PSU might mitigate the RX 580 GPU crashing issue, since you are using a cheap quality power supply. Get a decent quality PSU and then re-check your system.
Power supplies are an imperative part of your system that should not be taken lightly. Throwing in a budget PSU could result in poor power efficiency or even a wrecked system.
Hello, my name is Dr. Meklin and I have used the RX570 since 2019 and had the same issues peoples years later are posting. I did not fix them until 2024. It is not a ryzen problem, amd problem, or bios problem, or am4/b550+ chipset problem. How to fix the RX 570:
Take it apart, get your thermal paste, take off all the thermal pads and wear a latex glove after you get them off. Roll them all into a ball, it was years before I did this and mine was like hardened baked clay. You will now have a hard ball with chunks falling, put some thermal paste in it and rub it on every surface of every chunk and squeeze them together, fold them like steel until you have a perfect blob or soft play doh which is going to get hard later. roll out little tube shaped turds or whatever and put them all back on but down press down, the backplate will do that. i never really had a problem with the main thermal paste but redo it often probably 10 times since 2019. that isnt the part that is getting to hot, the VRAM is. i dont believe there is a way to detect it. drill a hole where the fans inside connect to each other, because you want that wire going out. if you want to do this your own way instead of my way, run one of the fan lines directly to the motherboard. this is how i fixed the rx570, by reducing the power draw. i have maxed out OCCT on overclock mode and drawn 250+ watts from this card, more than it probably can in standard setup. for my setup, one power line goes to the gpu, as it will not post without this (rx570 sapphire 8gb), and the other line goes to a MOLEX to 12v and 0.7v adapter. i just found it in my house but you can order one somewhere, it has two lines coming off the adapter once it makes connection to the molex, and i use the 12v line to hit my gpu fan. it maxes out that fan as it thinks it is a chassis fan and is detected. i played on this for a while and no crashes but eventually i got one even on standard tuning profile in radeon settings. at this point i realized i had achieved some stability, but i didnt put the backplate back on, nor modify it yet at this point with new paste and a fan. i have only drilled a hole in the bottom of the card and run the fan power linesout the bottom of the card where they split, and this has only reduced the power draw from the gpu's own fan power jumpers, nothing more.
so i realize i can overclock the card and play for a while, but i see an amd64 vega gpu crashing and he put intel fans on his gpu near the vram thermals. i could have fixed maybe just by putting the back plate on, but at this point, i knew i was truly facing a stability issue, not bios, not anything, i look at OCCT and see how fast a cpu heats up, my ryzen 3600x from 40c to 80c in 2 seconds on the 100% cpu max out test, and assume that is happening to the gpu and it really, really needs to be cool. see more posts about stability achieved with undervolt and max gpu fan 100%, so i set that as a staple. my 'chassis' intel i5 fan without a heat sink just hanging off the side of the vram area, almost touching my gpu fan cuz theres no room, taped on, i reccomend just drill a few small holes the same size as a motherboards how a cpu cooler mounts into that u can easily just let the fan 'sit' on top in those holes so it doesnt move it doesnt need to lock in at all.
i will make a video of my blasting out this card, and probably even show what happens if i unplug the third gpu fan which plugs DIRECTLY into my cpu chassis area and is maxed out 100% in my bios settings. this is a very very good gpu and the technology at that time wasnt fully understood by the 3rd party companies tweaking them in a 3 celcius chinese basement factory they assume we will get better cooling maybe like liquid. anyways enjoying my 40+ fps and oh yes i do notice when in dota 12 vs 12 and there are 24 ultimate spells going off at once, the very moment the gpu would have crashed with a small stutter that any modern computing system would experience when 48 sunstrikes go off at once, but it remains stable. others wont admit their placebo fix for this card were failures, they dont come back to the forum years later to help their poor brethren still using this card, their moms got them 2080ti's by now. but dr meklin is here and i have fixed this 4+ year issue, finally. be sure to repost this and check out the video on my youtube.com/indicator27 which will be up soon but you have enough here to visualize what you need to do to get this AWESOME (and i am literally a top 50 rust player) card working stable for probably a decade to come
